帮忙看个5529的程序.急急急
1208|0
 楼主| 淅淅沥沥沥 发表于 2014-7-10 15:12 | 显示全部楼层 |阅读模式
ADC, AD, dc, ADC1, se
想实现的功能就是在A0通道提取模拟信号并将ADC12MEMO的数据存到数组中,可是ADC12MEM0里面i就是不没有数据。求大神帮忙看看哪里出错了、我是新手。#include  <msp430.h>
#define   Num_of_Results   1000
unsigned int results[Num_of_Results] = {0x00};
void ADC_Init(void);
void main(void)
  WDTCTL = WDTPW | WDTHOLD;                 // Disable the Watchdog.
  ADC_Init();                               // Initialize ADC12
  ADC12CTL0 |= ADC12ENC;
   _EINT();
   while(1)
     ADC12CTL0 |= ADC12SC ;             // Start conversion
void ADC_Init(void)
  P1DIR |= BIT0;                             // set port to outputs
  P1DIR |= BIT3;                              // reset port outputs
  P6SEL |= 0x01;                            // select A0 input
  ADC12CTL0 |= ADC12ON+ADC12SHT0_1+ADC12REF2_5V+ADC12REFON; // Setup ADC12
  ADC12CTL1 = ADC12SHP+ADC12CONSEQ_2+ADC12SHS_1;           // Timer triggers sampling
  ADC12MCTL0 = ADC12INCH_0 + ADC12SREF_1;
  ADC12IE = 0x0001;                         // Enable ADC12IFG.0
  P1SEL |= BIT2;                            // Set for Timer A1
  P1DIR |= BIT2;
  TA0CCR0 =15;                              // Init TACCR0 w/ sample prd=CCR0+1
TA0CCR1 = 5;                               // Trig for ADC12 sample & convert
  TA0CCTL1 = OUTMOD_3;                       // Set/reset
  TA0CTL = TACLR | MC_1 | TASSEL_1;          // ACLK, clear TAR, up mode
// ADC12 Interrupt Service Routine
#pragma vector=ADC12_VECTOR
__interrupt void ADC12ISR (void)
  static unsigned int index = 0;
  P1OUT ^= 0x01;
  P1OUT ^= BIT3;
  results[index] = ADC12MEM0;             // Move results
  index = (index+1)%Num_of_Results ;
  if (index == Num_of_Results)
       index = 0;
