[技术问答]
Nano单片机 串口在掉电模式不能唤醒
2827|4
wxhdmf|  楼主 | 2014-7-11 10:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编写了一个简单的程序, 仅有串口,测试串口可否在掉电模式唤醒,中断唤醒后,会进入正常模式,
在主循环while里,执行__WFI();让cpu时钟停掉,发现串口发了6000次数据(aa 01 02 03 04),有18次没有返回,失误率大。求解答??
程序见下
#define UART0_BAUD                        2400
#define UART_RX_WORK_BIT        0x01
#define UART_TX_WORK_BIT        0x02
主程序
void Timer3_Init(void)
    volatile unsigned long delay = 5000;
    CLK->CLKSEL2 = (CLK->CLKSEL2 & ~CLK_CLKSEL2_TMR3_MASK)|CLK_CLKSEL2_TMR3_LXT;
        CLK->APBCLK |= CLK_APBCLK_TMR3_EN;
        TIMER3->CTL = TIMER_CTL_MODESEL_PERIODIC;
        TIMER3->PRECNT = 0;
        TIMER3->CMPR = (unsigned long)(32768/10 + 0.5);
        TIMER3->ISR = TIMER_ISR_TMRIS;        //Clear Interrupt Status
        // Enable TIMER3 Intettupt
        TIMER3->IER = TIMER_IER_TMRIE;
    NVIC_EnableIRQ(TMR3_IRQn);
        NVIC_SetPriority(TMR3_IRQn,2);
        while(delay--);
        // Start counting
        TIMER3->CTL |= TIMER_CTL_TMREN | TIMER_CTL_WAKEEN;
void TMR3_IRQHandler(void)
        TIMER3->ISR = TIMER3->ISR;        //清中断标志位
    if(timeout)
        if(--timeout == 0)
            timeout= 0;
                        UART0->CTL |= 0x200;
                        g_ucUart1WorkFlag &= ~UART_RX_WORK_BIT;
int32_t main(void)
        do
                UNLOCKREG();
        }while(GCR->RegLockAddr & 0x01 == 0);
    CLK->PWRCTL  = 0x0e;
    while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_HIRC_STB)); //等待时钟稳定
        CLK->CLKDIV0 = 0x00;
    CLK->PWRCTL |= CLK_PWRCTL_LXT_EN;        // for LXT
        while(!(CLK->CLKSTATUS & CLK_CLKSTATUS_LXT_STB));
     /* Select HCLK from HIRC */
    CLK->CLKDIV0 &= ~CLK_CLKDIV0_HCLK_MASK; /* divider is 0 */
    CLK->CLKSEL0 = (CLK->CLKSEL0 & ~CLK_CLKSEL0_HCLK_MASK) | CLK_CLKSEL0_HCLK_HIRC;         /* HCLK = 12MHz */
    uart0_init();
    Timer3_Init();
    OS_EnInt();
        while(1)
        if(g_ucUart1WorkFlag)
            if(UART0->FSR & UART_FSR_TE_F)
               g_ucUart1WorkFlag &= ~UART_TX_WORK_BIT;
                    __WFI();        //休眠
                else
            OS_DisInt();
                        CLK->PWRCTL = 0x5e;
                        SCB->SCR = 0x04;
                        OS_EnInt();
            if(!g_ucUart1WorkFlag)
                        __WFI();        //休眠
串口程序
void uart0_init(void)
        u32 tmp;
        /* Select UART Clock Source From 12Mhz*/
        CLK->CLKSEL1 = (CLK->CLKSEL1 & ~CLK_CLKSEL1_UART_MASK)|CLK_CLKSEL1_UART_HIRC;
        /* Set UART1 Pin */
        //GCR->PB_L_MFP &= ~(PB5_MFP_MASK | PB4_MFP_MASK);
        //GCR->PB_L_MFP |= PB5_MFP_UART1_TX | PB4_MFP_UART1_RX;
    MFP_UART0_TO_PORTA();
        /* Reset IP */
        GCR->IPRST_CTL2 |= GCR_IPRSTCTL2_UART0;
        GCR->IPRST_CTL2 &= ~GCR_IPRSTCTL2_UART0;
        /* Enable UART clock */
        CLK->APBCLK |= CLK_APBCLK_UART0_EN;
        /* Tx FIFO Reset & Rx FIFO Reset & FIFO Mode Enable */
        UART0->CTL |= UART_CTL_RX_RST;
          UART0->CTL |= UART_CTL_TX_RST;
        /* Set Rx Trigger Level, Parity & Data bits & Stop bits */
        UART0->TLCTL = ((DRVUART_FIFO_1BYTES << 8) |
                                        (DRVUART_PARITY_EVEN << 3) |
                                        (DRVUART_STOPBITS_1 << 2) |
                                        (DRVUART_DATABITS_8) );
        /* Set Time-Out */
//        UART0->TMCTL &= ~UART_TMCTL_TOIC;
//        UART0->TMCTL |= 20 & UART_TMCTL_TOIC;
        /* Set BaudRate */
        UART0->BAUD &= ~UART_BAUD_DIV_16_EN;
        //波特率计算公式为 UART_CLK / [(BRD+1)]
        tmp = CLK->CLKDIV0 & 0x0f00;
        UART0->BAUD |= (u32)(12000000.0/((tmp>>8)+1)/UART0_BAUD - 1);
        UART0->IER = DRVUART_RDAINT | DRVUART_WAKEUPINT;// | DRVUART_TOUTINT;
        NVIC_EnableIRQ(UART0_IRQn);
void uart0_send_str(u8 *str, u16 len)
    g_ucUart1WorkFlag |= UART_TX_WORK_BIT;
        while(len--)
                while(UART0->FSR & UART_FSR_TX_FULL_F);
                UART0->THR = *str++;
void UART0_IRQHandler(void)
        u32 status;
    status = UART0->ISR;
        //换醒中断
        if(status & DRVUART_WAKEUPINT)
                UART0->ISR |= DRVUART_WAKEUPINT;
        g_ucUart1WorkFlag |= UART_RX_WORK_BIT;
        timeout=4;
        //接收数据中断
        else if(status & DRVUART_RDAINT)
                if(UART0->FSR & 0x0800)
            bufdata[0]=UART0->RBR;
                uart0_send_str(&bufdata[0],1);
wxhdmf|  楼主 | 2014-7-11 10:54 | 只看该作者
串口唤醒掉电失败?求解答?
从小木丁丁| | 2014-7-11 17:26 | 只看该作者
掉电模式可以唤醒,但是串口无法使用?
wxhdmf|  楼主 | 2014-7-13 11:24 | 只看该作者
发6000次数据(aa 01 02 03 04),有18次没有返回,应该是
掉电模式没有唤醒。
henryh52| | 2014-7-15 13:29 | 只看该作者
坐等楼下强人出现。
