12864显示求助
1046|4
 楼主| D-player 发表于 2014-7-18 23:05 | 显示全部楼层 |阅读模式
12864显示一直出问题,背景能亮,但是无法显示。忙检测无法跳出,就算屏蔽了不执行忙检测也没有显示。刚从51转到430.求教
 楼主| D-player 发表于 2014-7-18 23:11 | 显示全部楼层
这是我写的12864的C文件。这个文件在51上执行没有任何问题。真心不明白啊
#include "msp430x54x.h"
#include <stdlib.h>
#include <stdio.h>
#include "PIN_DEF.H"
#include "12864.h"
#define unchar unsigned char
#define unint unsigned int
//12864初始化 控制端口置为输出
void _12864_init()
  P3DIR|=BIT7;
  P3OUT|=BIT7;
  P1DIR|=BIT2;
  P1OUT&=~BIT2;
  RW_OUT_MOD;
  E_OUT_MOD;
  RS_OUT_MOD;
//检测忙信号
unchar busy()
  unchar result;
  unchar record;
  data_in_mod;
  RS_OUT_MOD;
  RW_OUT_MOD;
  E_OUT_MOD;
  RW_H;
  RS_L;
  E_H;
  __delay_cycles(100);
  record=P4IN;
  result=(unchar)(record&0x80);
  E_L;
  return(result);
//写指令
void write(unchar cmd)
  while(busy());
  RS_OUT_MOD;
  RW_OUT_MOD;
  E_OUT_MOD;
  RS_L;
  RW_L;
  E_L;
  data_out_mod;
  P4OUT=cmd;
  E_H;
  E_L;
//写数据
void write_data(unchar data)
  RS_OUT_MOD;
  RW_OUT_MOD;
  E_OUT_MOD;
  RS_H;
  RW_L;
  E_L;
  data_out_mod;
  P4OUT=data;
  E_H;
  E_L;
//读数据
unchar read_data()
  RS_OUT_MOD;
  RW_OUT_MOD;
  E_OUT_MOD;
  unchar data;
  while(busy());
  data_in_mod;
  RS_H;
  RW_L;
  data=P4IN;
  E_L;
  return(data);
//确定基本参数如基本动作还是高级动作
void LCD_init()
  write(0x30);
  write(0x0c);
  write(0x01);
//基本动作显示字符的显示位子
void lcd_pos(unchar X,unchar Y)
  unchar pos;
  if(X==0)
  {X=0x80;}
  else if(X==1)
  {X=0x90;}
  else if(X==2)
  {X=0x88;}
  else if(X==3)
  {X=0x98;}
  pos=X+Y;
  write(pos);
//清屏
void LCD_clear()
  unchar hang,lie;
        write(0x34);//开扩充指令集
        for(hang=0;hang<32;hang++)
                                write(0x80+hang);//先写Y坐标
                                write(0x80);//写X坐标
                        for(lie=0;lie<16;lie++)
                                write_data(0X00);
                 write(0x88);//写X坐标
                                //X范围0~7
                                write_data(0X00);
        write(0x36);
        write(0x30);
xyz549040622 发表于 2014-7-19 08:02 | 显示全部楼层
忙检测都跳不出来?是不是时序问题呢?430的延时不够?你网上找个430的12864程序烧进去试试,但极力怀疑是不是你对430不熟悉引起的问题,所以建议你先烧别人好的工程试试
dirtwillfly 发表于 2014-7-19 21:48 | 显示全部楼层
好长的代码
dirtwillfly 发表于 2014-7-20 21:03 | 显示全部楼层
楼主问题解决了吗?
