[PIC®/AVR®/dsPIC®产品] kit3 无法烧写程序
3028|3
 楼主| jdx0606 发表于 2014-7-22 13:08 | 显示全部楼层 |阅读模式
PICkit 3 detected
Connecting to PICkit 3...
Running self test...
Self test completed
Firmware Suite Version...... 01.26.81
Firmware type......................Baseline
PICkit 3 Connected.
The target has invalid calibration data (0).
Programming...
The following memory regions failed to program correctly:
Program Memory
Address: 00000000 Expected Value: 00000025 Received Value: 00000000
Programming failed
yewuyi 发表于 2014-7-22 18:43 | 显示全部楼层
都已经提示你:The target has invalid calibration data (0).
你怎么可能烧写正确?
 楼主| jdx0606 发表于 2014-7-25 20:26 | 显示全部楼层
问题已解决,哈哈,烧写端子上并上电容了
zhxx88 发表于 2016-3-1 16:43 | 显示全部楼层
请问你是怎么解决的?
