pic18f26k20编译问题
2285|1
 楼主| zhouyuxin1977 发表于 2014-7-23 15:56 | 显示全部楼层 |阅读模式
编译后出现以下错误,请高手指点:
Make: The target "D:\Source code\FE2 PIC26K20 QP9D111 PTZ\export\26k20_sample_code.cof" is out of date.
Executing: "C:\Program Files (x86)\Microchip\MPLABC18\v3.43\bin\mplink.exe" /p18F26K20 /l"C:\Program Files\Microchip\mplabc18\v3.42\lib" /k"D:\Source code\FE2 PIC26K20 QP9D111 PTZ" "mt9d131.o" "sensor.o" "uart.o" "eep.o" "i2c.o" "pic.o" "mdin240.o" "delay.o" "mid_i2c.o" "mid_uart.o" "uart2i2c.o" "avs7201.o" "avs7201_1ch_cctv_out.o" "avs7201_cctv_out.o" "avs7201_sensor_out.o" "main_flow_uart2i2c.o" "main.o" "main_flow_cctv_sample.o" "main_flow_sensor_sample.o" /u_CRUNTIME /z__MPLAB_BUILD=1 /m"26k20_sample_code.map" /w /o"26k20_sample_code.cof"
MPLINK 4.44, Linker
Device Database Version 1.9
Copyright (c) 1998-2011 Microchip Technology Inc.
Error - section '.idata_avs7201.o' can not fit the section. Section '.idata_avs7201.o' length=0x00000120
Errors    : 1
Link step failed.
Release build of project `D:\picdemo\mytest1\project\sample\26k20_sample_code.mcp' failed.
Language tool versions: mpasmwin.exe v5.46, mplink.exe v4.44, mcc18.exe v3.43, mplib.exe v4.44
Wed Jul 23 15:22:09 2014
BUILD FAILED
我查了一下,好像是数据空间的问题,不知如何解。
Rain_King 发表于 2014-7-23 18:02 | 显示全部楼层
是一直移植实时系统,出现的问题吧....貌似变量空间不够,或者说是你的数组太大导致的....
