[Kinetis] 【经验分享】KE02在CW中使用常量形式初始化EEPROM值
3958|6
 楼主| FSL_TICS_ZJJ 发表于 2014-7-24 16:35 | 显示全部楼层 |阅读模式
【经验分享】KE02CW中使用常量形式初始化EEPROM
一,  经验分享描述
        写这篇经验分享的原因是,之前有一个客户,他希望在KE02的芯片中,不要出现使用EEPROM操作命令的形式初始化EEPROM,但是需要芯片的EEPROM中就有他所规定好的数据,以便于程序直接调用。其实就把EEPROM中的数据当做固定在flash的数据一样使用。而目前也没有看到使用具体的工具去直接烧写EEPROM,所以我们就想是否能够像flashconstant的定义一样定义EEPROM的数据呢?通过实际操作发现还是切实可行的,于是就分享了这篇在CW中如何直接定义常量到EEPROM中的经验分享。其实方法和之前本人分享过的经验分享“KL系列在CW中定义常量到指定的flash位置”,方法一致,只是地址改为EEPROM的地址。
二,  经验分享实现
通过前面的介绍,可以知道,是可以直接在CW中定义常量到EEPROM的,这里就讲解具体如何实现。
下面通过CWPE新建的KE02的工程为例,详细讲解如何实现EEPROM中常量的定义。
1,在.ld中开辟一段属于EEPROM的内存
大家都知道KE02EEPORM具有256个字节,其实地址为0x10000000, 所以就开辟一个段,其实地址为0x10000000,长度为0X00000100.
如下图所示:
关于.ld文件,可以在工程的Project_settings下的Linker_Files中找到。
2,定义具体的输出段情况
定义如下:
如果想具体了解段内的意思,可以参考附件中的ld.pdf,在第三章中有讲相应的脚本含义。
3,在主程序中添加常量定义代码
定义需要使用如下格式,
__attribute__((section (".romsymbols"))) char test[256]={};
这里,我们以从0开始递增的方式填满EEPROM的256个字节,具体定义如下:
__attribute__((section (".romsymbols"))) char test[256] ={
0x0,0x1,0x2,0x3,0x4,0x5,0x6,0x7,0x8,0x9,0xA,0xB,0xC,0xD,0xE,0xF,
0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1A,0x1B,0x1C,0x1D,0x1E,0x1F,
0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2A,0x2B,0x2C,0x2D,0x2E,0x2F,
0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3A,0x3B,0x3C,0x3D,0x3E,0x3F,
0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4A,0x4B,0x4C,0x4D,0x4E,0x4F,
0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5A,0x5B,0x5C,0x5D,0x5E,0x5F,
0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6A,0x6B,0x6C,0x6D,0x6E,0x6F,
0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7A,0x7B,0x7C,0x7D,0x7E,0x7F,
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8A,0x8B,0x8C,0x8D,0x8E,0x8F,
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9A,0x9B,0x9C,0x9D,0x9E,0x9F,
0xA0,0xA1,0xA2,0xA3,0xA4,0xA5,0xA6,0xA7,0xA8,0xA9,0xAA,0xAB,0xAC,0xAD,0xAE,0xAF,
0xB0,0xB1,0xB2,0xB3,0xB4,0xB5,0xB6,0xB7,0xB8,0xB9,0xBA,0xBB,0xBC,0xBD,0xBE,0xBF,
0xC0,0xC1,0xC2,0xC3,0xC4,0xC5,0xC6,0xC7,0xC8,0xC9,0xCA,0xCB,0xCC,0xCD,0xCE,0xCF,
0xD0,0xD1,0xD2,0xD3,0xD4,0xD5,0xD6,0xD7,0xD8,0xD9,0xDA,0xDB,0xDC,0xDD,0xDE,0xDF,
0xE0,0xE1,0xE2,0xE3,0xE4,0xE5,0xE6,0xE7,0xE8,0xE9,0xEA,0xEB,0xEC,0xED,0xEE,0xEF,
0xF0,0xF1,0xF2,0xF3,0xF4,0xF5,0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFE,0xFF
4,测试结果
    本次测试是以FRDM_KE02开发板为平台,调试使用板上opensda
在程序下载之前,首先将KE02的整个flash全面擦除,即选择mass erase,这样保证KE02在下载程序后,它的EEPROM不是之前的值。
配置mass erase如下,
首先选择 RUN->Debug configurations,然后配置如下
勾选了always mass erase on connect 之后,点击OK,并debug
测试结果如下:
使用内存查看:
本例程还提供使用串口实行打印出EEPROM的数据,结果和定义一致。
三,     附件
附件提供了本文的PDF,参考文档以及测试代码。
后续还会出一片如何在IAR以及KEIL下实现同样的功能。
ld.pdf (689.77 KB, 下载次数: 55)
【经验分享】KE02在CW中使用常量形式初始化EEPROM值.pdf (475.17 KB, 下载次数: 64)
KE02_EEPROM_CONST.rar (265.37 KB, 下载次数: 49)
 楼主| FSL_TICS_ZJJ 发表于 2014-7-24 16:37 | 显示全部楼层
不足之处,恳请指正,同时也欢迎大家分享自己的经验。
如果大家有其他工具可以直接烧写KE02的EEPORM的,也欢迎推荐出来。
caijun_2012 发表于 2014-7-31 17:02 来自手机 | 显示全部楼层
谢谢了,楼主,很有用
FSL_TICS_Jeremy 发表于 2014-8-5 10:49 | 显示全部楼层
很好的经验分享,不能沉啊!
Jay1987887 发表于 2014-8-19 16:45 | 显示全部楼层
谢谢斑竹分享,学习一下!
nyxaa 发表于 2014-9-16 20:13 | 显示全部楼层
来学习
lwk00c 发表于 2015-8-2 07:18 | 显示全部楼层
谢谢楼主,顶起
