【系统方块图】
【规格说明】
Voice and Video Processor Features: DaVinci TMS320DM36x - ARM9 Core and up to 432MHz (Max.)
- Video Codec: support H.264, MPEG-4. MPEG-2, MJPEG, WMV9
- Video Resolution/Frame Rate: 1080P 30 FPS
- Support I/F: USB 2.0, EMAC, UART, MMC/SD, I2C, SPI, HPI, McBSP
- IO Supply: 1.8V and 3.3V
Ethernet PHY Features: DP83848K - Fully Supports IEEE 802.3af Specification
- Supports Use of Low-Cost Silicon Rectifiers
- Programmable Inrush Current Control
- Fixed 450-mA Current Limit
- Fixed and Adjustable UVLO Options
- Open-Drain, Power-Good Reporting
- Overtemperature Protection
Audio Codec Features: TLV320AIC3254 - PowerTune™ technology
- DAC (Stereo, 48ksps, Dvdd=Avdd=1.8V)
- ADC (Stereo, 48ksps, Dvdd=Avdd=1.8V)
- miniDSP: 两个独立的内核也可以同步运作,一个在ADC,另一个在DAC。
- 支持I2C或SPI控制。
- Integrated LDO for single-supply operation
- Sample rates from 8kHz to 192kHz
