[FPGA] 时序约束出现问题
1085|0
 楼主| 3008202060 发表于 2014-7-30 09:12 | 显示全部楼层 |阅读模式
我没有办法对时钟进行约束,出现的是这样的,我把它自动生成的注释掉还是不行,Ignored create_clock: Incorrect assignment for clock.  Source node: SYSCLK already has a clock(s) assigned to it.  Use the -add option to assign multiple clocks to this node.  Clock was not created or updated.跪求解决方法
