[STM8] @svlreg修饰符的使用遇到问题,求助
2656|0
 楼主| oldpig 发表于 2014-7-30 09:25 | 显示全部楼层 |阅读模式
AN, BUG, UG, STM, ST
我需要在中断函数的定义中用到@svlreg修饰符,如下:
@far @interrupt @svlreg void Timer2_Interrupt(void)
但编译时出以下错误:
clnk -lE:\works\projects\STM\STM8\lean\lean\Lib  -o debug\lean.sm8 -llib -mdebug\lean.map -p debug\lean.lkf
#error clnk debug\lean.lkf:1 symbol c_lreg not defined (debug\stm8_interrupt_vector.o )
The command: "clnk -lE:\works\projects\STM\STM8\lean\lean\Lib  -o debug\lean.sm8 -llib -mdebug\lean.map -p debug\lean.lkf " has failed, the returned value is: 1
exit code=1.
将@svlreg 修饰符去掉,编译正常通过,请问我错在哪里?谢谢!
