数码管没有显示温度呀,就显示了0000
不懂错在哪了,实在调不出来了,求大家帮忙解答一下,谢谢
以下为代码:
#include<iom16v.h>
#include<macros.h>
#define uint unsigned int
#define uchar unsigned char
#define sclon PORTA|=BIT(0)
#define scloff PORTA&=~BIT(0)
#define dion PORTA|=BIT(1)
#define dioff PORTA&=~BIT(1)
#define dqon PORTD|=BIT(2)
#define dqoff PORTD&=~BIT(2)
float temperature;
uchar templ=0;
uchar temph=0;
float t;
extern const unsigned char
tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
/*void delay(uint z)
uint x,y;
for(x=0;x<110;x++)
for(y=z;y>0;y--);
void dataout(uchar temp)
uchar i,temp1;
temp1=tab[temp];
for(i=0;i<8;i++)
scloff;
NOP();
if((temp1&0x80)!=0x80)
dioff;
NOP();
else
NOP();
dion;
NOP();
sclon;
NOP();
NOP();
temp1<<=1;
NOP();
NOP();
//scloff;
void delay1(void)
uint i;
for(i=0;i<200;i++);
void delay(uint k)
uint n;
n=0;
while(n<k)
n++;
return;
void display(uint k)
PORTA&=0x03;
dataout(k/1000);
delay(200);
PORTA|=0x04;
dataout(k/100%10);
delay(200);
PORTA&=0x0b;
PORTA|=0x08;
dataout(k/10%10);
delay(200);
PORTA|=0x0c;
dataout(k%10);
delay(200);
void init_18b20(void)
uchar x=0;
dqon;
delay(8);
dqoff;
delay(85);
dqon;
delay(14);
read_18b20(void)
uchar i=0,data=0;
for(i=10;i>2;i--)
dqon;
delay(1);
dqoff;
data>>=1;
dqon;
DDRD=0xfb;
if(PIND&0x04)
data|=0x80;
DDRD=0xff;
delay(4);
return (data);
write_18b20(uchar data)
uchar i=0;
for(i=10;i>2;i--)
dqoff;
if(data&0x01)
dqon;
else
dqoff;
delay(5);
dqon;
data>>=1;
delay(4);
read_temp(void)
init_18b20();
write_18b20(0xcc);
write_18b20(0x44);
delay(125);
init_18b20();
write_18b20(0xcc);
write_18b20(0xbe);
templ=read_18b20();
temph=read_18b20();
temperature=((temph*256)+templ)*0.0625;
delay(200);
return (temperature);
void main(void)
DDRA=0xff;
DDRD=0xff;
display(0);
while(1)
//delay();
t=read_temp();
display(t);
//delay();
NOP();
}图片如下
