Clean: Deleting intermediary and output files.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_main.obj" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_main.sdb" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_main.rlf" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_main.lst" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_isr.obj" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_isr.sdb" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_isr.rlf" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_isr.lst" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_init.obj" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_init.sdb" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_init.rlf" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_init.lst" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_Statemachine.obj" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_Statemachine.sdb" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_Statemachine.rlf" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_Statemachine.lst" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_traps.obj" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_traps.sdb" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_traps.rlf" doesn't exist.
Clean Warning: File "F:\Microchip\pic\program\a\Solar Microinverter_traps.lst" doesn't exist.
Clean: Deleted file "F:\Microchip\pic\program\a\biancheng.mcs".
Clean: Done.
Build F:\Microchip\pic\program\a\biancheng for device 33FJ16GS504
Using driver f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe
Executing: "f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe" -C "F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_main.c" -q --chip=33FJ16GS504 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [141] F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_main.c; 32.37 can't open include file "Solar Microinverter_main.h": No such file or directory
Executing: "f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe" -C "F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_isr.c" -q --chip=33FJ16GS504 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [141] F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_isr.c; 32.36 can't open include file "Solar Microinverter_isr.h": No such file or directory
Executing: "f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe" -C "F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_init.c" -q --chip=33FJ16GS504 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [141] F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_init.c; 32.37 can't open include file "Solar Microinverter_init.h": No such file or directory
Executing: "f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe" -C "F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_Statemachine.c" -q --chip=33FJ16GS504 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [141] F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_Statemachine.c; 32.45 can't open include file "Solar Microinverter_Statemachine.h": No such file or directory
Executing: "f:\Microchip\HI-TECH Software\DSPICC\STD\9.62\bin\dspicc.exe" -C "F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_traps.c" -q --chip=33FJ16GS504 -P --runtime=default --opt=default -D__DEBUG=1 --rom=default --ram=default -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [141] F:\MCHP SMPS Design Packages\230Vac Grid-Connected Solar Microinverter Design Package_v2013-08-13\Source Code\src\Solar Microinverter_traps.c; 43.29 can't open include file "p33Fxxxx.h": No such file or directory
Don't know how to compile sourcefile F:\Microchip\MPLAB C30\lib\dsPIC33F\libp33FJ16GS504-coff.a
********** Build failed! **********
