[PIC®/AVR®/dsPIC®产品] PIC32MZ的硬件I2C
10497|4
 楼主| 强仔00001 发表于 2014-8-2 15:39 | 显示全部楼层 |阅读模式
我现在调到PIC32MZ的I2C,本来想用PIC官方的harmony库函数来写一个初始化MPU6050的程序。但试了两三天也不行,无奈之下看了PIC32MZ的I2C参考手册的那部分。写了一个寄存器版的读取MPU6050的程序。当还是有问题。
我的代码是:
  1. void I2C1_Init()
  3.     uint32_t actualClock;
  4.     PLIB_I2C_BaudRateSet ( MY_I2C_ID, MY_CLOCK_FREQUENCY, MY_BAUD_RATE);
  5.     actualClock = PLIB_I2C_BaudRateGet ( MY_I2C_ID, MY_CLOCK_FREQUENCY );
  6.     if(abs(actualClock-MY_BAUD_RATE) > MY_BAUD_RATE/10);
  7.     {
  8.         while(1);
  9.     }
  10.     I2C1CONbits.A10M = 0;
  11.     I2C1CONbits.SMEN = 0;
  12.     I2C1CONbits.ON = 1;
  13. }
  14. void I2C1_Start()
  15. {
  16.     I2C1CONbits.SEN = 1;
  17.     while(I2C1STATbits.P);
  18. }
  19. void I2C1_SendData(uint8_t Data)
  20. {
  21.     I2C1TRNbits.I2CTRN = Data;
  22.     while(I2C1STATbits.TBF);
  23. }
  24. void I2C1_Stop()
  25. {
  26.     I2C1CONbits.PEN = 1;
  27. }
  28. #define OAR1_ADD0_Set ((uint16_t)0x0001)
  29. #define OAR1_ADD0_Reset ((uint16_t)0xFFFE)
  30. void Send7bitsAddress(uint8_t Address,uint8_t I2C_Direction)
  31. {
  32.     if(I2C_Direction == 0)
  33.     {
  34.         Address |= OAR1_ADD0_Set;
  35.     }
  36.     else
  37.     {
  38.         Address &= OAR1_ADD0_Reset;
  39.     }
  40.     I2C1TRNbits.I2CTRN = Address;
  41. }
  42. void I2C_Byte_Write(uint8_t SlaveAddress,uint8_t REG_Address,uint8_t REG_data)
  43. {
  44.     I2C1_Start();
  45.     Send7bitsAddress(SlaveAddress,1);
  46.     while(I2C1STATbits.R_W);
  47.     while(I2C1STATbits.TBF);
  48.     I2C1_SendData(REG_Address);
  49.     while(I2C1STATbits.TBF);
  50.     I2C1_SendData(REG_data);
  51.     while(I2C1STATbits.TBF);
  52.     I2C1_Stop();
  53. }
  54. void MPU_6050_Init(void)
  55. {
  56.     I2C_Byte_Write(MPU6050_SlaveAddress,PWR_MGMT_1,0x00);
  57.     delay(50000);
  58.     I2C_Byte_Write(MPU6050_SlaveAddress,SMPLRT_DIV,0x07);
  59.     delay(50000);
  60.     I2C_Byte_Write(MPU6050_SlaveAddress,MPU6050_CONFIG,0x06);
  61.     delay(50000);
  62.     I2C_Byte_Write(MPU6050_SlaveAddress,GYRO_CONFIG,0x08);
  63.     delay(50000);
  64.     I2C_Byte_Write(MPU6050_SlaveAddress,ACCEL_CONFIG,0x08);
  65. }
  66. int main ( void )
  67. {
  68.     SYS_DEVCON_PerformanceConfig(SYS_CLK_FREQUENCY);
  69.     I2C1_Init();
  70.     while(1)
  71.     {
  72.        MPU_6050_Init();
  73.     }
  74.   /*
  75.    Initialize the application. */
  76. /* SYS_Initialize(NULL);
  77.     while (true)
  78.     {
  79.         // Maintain the application's state machine.
  80.         SYS_Tasks();
  81.     }
  82. */
  83.     /* Should not come here during normal operation */
  84.     PLIB_ASSERT(false, "leaving main");
  85.
  86.     return (EXIT_FAILURE);
  87. }
但总是卡死在了while(1)的那句话,我想也想不明白我已经设置了100K的SCL频率,但还是有超过10%的误差。
第二个问题是卡在了while(I2C1STATbits.TBF);这句话,就是得不到应答。
同样的问题,问题一般都是很快会得较满意的回复。
希望有大神的解救,希望我的问题能得到解决。:'(
donghailao 发表于 2014-8-4 18:37 | 显示全部楼层
你这是高档机芯,我没用过,还要向你学习。
根据我在中、低档芯片里I2C的经验,问题多数出在底层初始化时序,没有严格按照 I2C 器件手册里要求的来。
可以考虑先给脉冲加入延时等待,成功后,逐步紧俏底层的延时,以提高效率。
yewuyi 发表于 2014-8-5 08:21 | 显示全部楼层
你先回答:以前弄过IIC吗?如果以前弄过,请问以前调通了吗?
 楼主| 强仔00001 发表于 2014-8-6 16:30 | 显示全部楼层
根据我在中、低档芯片里I2C的经验,问题多数出在底层初始化时 ...
硬件I2C怎样加延时??
donghailao 发表于 2014-8-13 10:43 | 显示全部楼层
先用普通 I/O口,自己编写软件 模拟 IIC的时序(主机),底层可以添加延时。
用芯片自带的、现成的硬件口资源时,芯片底层的时序我只能调整波特率和一些位设置,实际上我没了延时的权利。在这种情况下如果通信不成功,感觉检查IIC口的初始化设置,如地址位数、应答位设置等什么参数。
32位的我没用过。
兼顾汇报给3#yewuyi版:
我以前在PIC18系用片上硬件资源 主机,驱动成功 PCF8583时钟成功
在PIC16、pic18片上普通I/O模拟成功了主机,也是驱动的8583芯片
不会上图我,顺便问问怎么上图,笨啊。
