[STM32F1] 我写的modbus rtu 程序怎么不行,牛人帮忙看下
1560|3
 楼主| 长缨在手 发表于 2014-8-4 22:13 | 显示全部楼层 |阅读模式
include "stm32f10x.h"
u8 i;
u8 Com0_id = 0x05;//本机串口0的通讯地址
u8 Uart0_rev_buff[100];//com0串口接收缓冲区
u8 Uart0_send_buff[100];//com0串口发送缓冲区
vu8 Uart0_rev_count;
vs8 Uart0_send_counter = 0;
vu8 Uart0_rev_comflag=0;
vu8 Crc_counter = 0;//com0校验计数器
vu8 Uart1_Rx_Num=0;
vu8 *Uart0_send_pointer = Uart0_send_buff;//com0串口发送指针
vu16 Mkgz_bz = 0;//模块故障标志1:输入异常,2:过压,3:欠压,4:过温
vu16 Out_current = 50;//输出电流
vu16 Out_voltage = 240;//输出电压
vu16 Mkzt_bz = 0;//模块状态标志
vu16 OutX_current = 1000;//输出限流
vu16 Jc_voltage = 2530;//均充电压
vu16 Fc_voltage = 2400;//浮充电压
vu16 user_day = 1825;//使用天数
void Delay(vu32 nCount);
unsigned short getCRC16(volatile unsigned char *ptr,unsigned char len) ;
//void mov_data(u8 a[100],u16 b[50],u8 c);
void Modbus_Function_3(void);
void Modbus_Function_6(void);
void RCC_cfg();
void GPIO_cfg();
void USART_cfg();
void NVIC_Configuration();
void Timer2_Configuration();
void Com0_Communication();
void USART1_IRQHandler();
void TIM2_IRQHandler();
void main()
    RCC_cfg();
    GPIO_cfg();
    USART_cfg();
while(1)
{        Com0_Communication();
unsigned char i;
unsigned short crc = 0xFFFF;
if(len==0)
len = 1;
while(len--)
crc ^= *ptr;
for(i=0; i<8; i++)
if(crc&1)
crc >>= 1;
crc ^= 0xA001;
else
crc >>= 1;
ptr++;
return(crc);
u16 tempdress = 0;
u8 i = 3;
u16 crcresult;
tempdress= (Uart0_rev_buff[2] << 8) + Uart0_rev_buff[3];
if((tempdress >= 0x0120) & (tempdress + Uart0_rev_buff[5] < 0x0132))
Uart0_send_buff[0] = Com0_id;
Uart0_send_buff[1] = 0x03;
Uart0_send_buff[2] = 2 * Uart0_rev_buff[5];
Uart0_send_counter = 2 * Uart0_rev_buff[5] + 3;
switch(tempdress)
case 0x0120:
Uart0_send_buff = Mkgz_bz & 0xff;
i++;
Uart0_send_buff = (Mkgz_bz >> 8) & 0xff;
i++;
}//后面不放break的目的是继续往下执行
case 0x0122:
   Uart0_send_buff = Out_voltage & 0xff;
   i++;
   Uart0_send_buff = (Out_voltage >> 8) & 0xff;
   i++;
case 0x0124:
Uart0_send_buff = Out_current & 0xff;
i++;
Uart0_send_buff = (Out_current >> 8) & 0xff;
i++;
case 0x0126:
Uart0_send_buff = Mkzt_bz & 0xff;
i++;
Uart0_send_buff = (Mkzt_bz >> 8) & 0xff;
i++;
case 0x0128://这个地址是备用的里面的数据没有意义
Uart0_send_buff = 0x00;
i++;
i++;
case 0x012A:
Uart0_send_buff = OutX_current & 0xff;
i++;
Uart0_send_buff = (OutX_current >> 8) & 0xff;
i++;
case 0x012C:
Uart0_send_buff = Jc_voltage & 0xff;
i++;
Uart0_send_buff = (Jc_voltage >> 8) & 0xff;
i++;
case 0x012E:
Uart0_send_buff = Fc_voltage & 0xff;
i++;
Uart0_send_buff = (Fc_voltage >> 8) & 0xff;
i++;
case 0x0130:
i++;
i++;
//UCSRB |= (1<<TXCIE)|(1<<TXEN);//发送、发送中断允许
crcresult = getCRC16(Uart0_send_buff,Uart0_send_counter);
Uart0_send_buff[Uart0_send_counter] = crcresult & 0xff;
Uart0_send_buff[Uart0_send_counter+1] = (crcresult >> 8) & 0xff;
Uart0_send_counter = Uart0_send_counter+1;
//Uart0_send_pointer = Uart0_send_buff;
//USART_SendData(USART1, *Uart0_send_pointer++);
//USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
for(i=0;i<Uart0_send_counter+1;i++)
                  USART_SendData(USART1,Uart0_send_buff);
                  while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==0);
u16 tempdress = 0;
u8 tx_flat = 0;
u16 crcresult;
tempdress = (Uart0_rev_buff[2]<<8) + Uart0_rev_buff[3];
switch(tempdress)
case 0x0126:
Mkzt_bz = (Uart0_rev_buff[4]<<8) + Uart0_rev_buff[5];
if(user_day > 0)
tx_flat = 1;
}break;
case 0x012A:
OutX_current = (Uart0_rev_buff[4]<<8) + Uart0_rev_buff[5];
if(user_day > 0)
tx_flat = 1;
}break;
case 0x012C:
Jc_voltage = (Uart0_rev_buff[4]<<8) + Uart0_rev_buff[5];
if(user_day > 0)
tx_flat = 1;
}break;
case 0x012E:
Fc_voltage = (Uart0_rev_buff[4]<<8) + Uart0_rev_buff[5];
if(user_day > 0)
tx_flat = 1;
}break;
case 0x01EE:
user_day = (Uart0_rev_buff[4]<<8) + Uart0_rev_buff[5];
tx_flat = 1;
//eeprom_write_word (&user_day_eep,user_day);
}break;
default: //命令码无效不应答
tx_flat = 0;
if(tx_flat == 1)
Uart0_send_buff[1] = 0x06;
Uart0_send_buff[2] = Uart0_rev_buff[2];
Uart0_send_buff[3] = Uart0_rev_buff[3];
Uart0_send_buff[4] = Uart0_rev_buff[4];
Uart0_send_buff[5] = Uart0_rev_buff[5];
Uart0_send_counter = 6;
Uart0_send_counter = Uart0_send_counter+2;
void Com0_Communication(void)
s8 i =0;
//GPIO_SetBits(GPIOA,GPIO_Pin_2);
if(Uart0_rev_comflag == 1)//接收完成标志=1处理,否则退出
  {  //Uart0_rev_comflag=0;
  if(Uart0_rev_buff[0] == Com0_id)//地址错误不应答
    unsigned short crcresult;
    unsigned char temp[2];
    crcresult = getCRC16(Uart0_rev_buff,Crc_counter-2);
    temp[1] = crcresult & 0xff;
    temp[0] = (crcresult >> 8) & 0xff;
    if((Uart0_rev_buff[Crc_counter-1] == temp[0])&&(Uart0_rev_buff[Crc_counter-2] == temp[1]))//crc校验错误不应答
       // GPIO_ResetBits(GPIOA,GPIO_Pin_2);
      switch(Uart0_rev_buff[1])
            case 0x03:
               if(user_day > 0)
                    Modbus_Function_3();
          break;
          case 0x06:
              Modbus_Function_6();
          break;
  //Uart0_rev_comflag = 0;
  for(i = 100;i > -1;i--)
      Uart0_rev_buff = 0;
for(; nCount != 0; nCount--);
void RCC_cfg()
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA  | RCC_APB2Periph_USART1, ENABLE);
       RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);
//IO口配置
void GPIO_cfg()
       GPIO_StructInit(&GPIO_InitStructure);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
       GPIO_Init(GPIOA , &GPIO_InitStructure);
      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
      GPIO_Init(GPIOA, &GPIO_InitStructure);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
void USART_cfg()
     USART_InitTypeDef USART_InitStructure;
     USART_InitStructure.USART_BaudRate = 9600;
     USART_InitStructure.USART_WordLength = USART_WordLength_8b;
     USART_InitStructure.USART_StopBits = USART_StopBits_1;
     USART_InitStructure.USART_Parity = USART_Parity_No ;
     USART_InitStructure.USART_HardwareFlowControl =  USART_HardwareFlowControl_None;
     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
     USART_Init(USART1, &USART_InitStructure);
     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
     USART_Cmd(USART1, ENABLE);
void Timer2_Configuration(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_DeInit(TIM2);
  TIM_TimeBaseStructure.TIM_Period=8;
  TIM_TimeBaseStructure.TIM_Prescaler=(36000-1);
  TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
  TIM_ClearFlag(TIM2,TIM_FLAG_Update);//清除更新标志位
  //TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
  TIM_Cmd(TIM2,DISABLE);
void NVIC_Configuration(void)//定时器2和串口1中断配置
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_SetPriorityGrouping(NVIC_PriorityGroup_0);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);//NVIC_Init函数被包含在misc.c文件中。
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =2;
void TIM2_IRQHandler(void)
  if(TIM_GetITStatus(TIM2,TIM_IT_Update)!=RESET)//检查溢出信号
    TIM_ITConfig(TIM2,TIM_IT_Update,DISABLE);
    TIM_ClearITPendingBit(TIM2,TIM_IT_Update);//清除溢出标志
     Uart0_rev_comflag=1;
void USART1_IRQHandler(void)
      if(USART_GetITStatus(USART1,USART_IT_RXNE) != RESET) //中断产生
      USART_ClearITPendingBit(USART2,USART_IT_RXNE); //清除中断标志
      Uart0_rev_buff[Uart1_Rx_Num] = USART_ReceiveData(USART2);
      Uart1_Rx_Num++;
      //Crc_counter=Uart1_Rx_Num-1;
      TIM_Cmd(TIM2,ENABLE);
 楼主| 长缨在手 发表于 2014-8-4 22:20 | 显示全部楼层
1.定时器2的中断好像跳不出来
2.我串口接收中断的意思是想等数据全接受完了,定时器中断超过4ms产生标志位Uart0_rev_comflag=1,可是调试的时候为什么Uart0_rev_comflag不等于1啊?????
ieexplorer 发表于 2014-8-5 00:17 | 显示全部楼层
太长了,也不懂modbus,不过我觉得至少Uart0_rev_comflag前要加volatile吧
airwill 发表于 2014-8-5 10:59 | 显示全部楼层
程序太长了, 什么思路都不说, 光一个 "不行" 让人家怎么猜得到你的问题?
象这种问题, 你应该把你的编程思路说清楚, 大家帮你参谋参谋.
至于调试, 还得靠你自己, 比较你有程序, 有板子和环境, 可以跟踪调试看波形, 而别人只能靠猜!
