[产品供应] 日本精密二手探针台,UF3000
2086|0
 楼主| Daisy220 发表于 2014-8-11 13:52 | 显示全部楼层 |阅读模式
TE, AN, TI, IO, ck
135000美金8 c" r$ b1 W  E
ACCRETECH / TSK UF 3000 Prober- z' i& u+ F0 j$ }. p
Loader Type: TSK ' Q& h# N  L3 Q9 F3 r+ V7 j6 _
Number of Loaders: TSK Single port% H6 @1 F5 B( M  }7 v+ e% Y7 F
Cassette ID Reader: No - L: Y) o( l, `( ^9 H/ w$ F; S8 ?
Chuck Size: 12"
Chuck Top Material: nickel coating+ o3 s. ?1 Z! F- q! n; V7 t9 c
Low Temp Chuck: Yes
Chuck Temperature Range: -40℃ to 150℃ ( t) z5 d5 K: ~8 x
Temperature Unified Chuck Option: Yes, Type: ARTS-HC12
Low Noise Chuck Option: No7 x! \) D0 G. m. Z: L- q
Manipulator: Hinge MHF60009 A7 S' J1 v: W% v: z
Test System Interface: Advantest T5377
External Chiller Unit: Yes 9 R6 ~* j2 W6 A4 T6 t5 J
High Force Z Drive: Yes
Auto Probe to Pad Alignment: Yes + v& H3 \$ O0 X1 W5 {
Needle Mark Inspection: Yes # q+ W1 |7 ^/ {! P
Fail Mark Inspection: Yes ; x4 @+ ]+ V0 r! S1 y  Q
Backside Wafer ID OCR: INSIGHT 1701
Wafer ID Barcode Reader: No + f$ R& z0 S, e7 @7 T* D4 A
Needle Cleaning Option (Double Brush): No
Auto Needle Height and Align: Yes , P2 h$ ~' _# p5 a+ Q
Soak Time Option: Yes
Probe Card Changer: Auto/Manual
3-64 Multi-site Probing: 1~256
GPIB Interface: Yes, Accretech STD command
RS232 Interface: Yes & Z, N  _8 w, |3 L% c
RF Tag: Yes $ [. o% _) g/ k0 Y8 T6 H* A
Integrated Printer: No
Software Version: S5.14.12 ( c5 i! {: i& L* e6 W. h
Boot ROM Version: Yes P/C unit no.: MIC1040-14-1-A
Manual Set: No ) U" ?# D; P1 m
Production tool
Under OEM Service Contract: No
2006 vintage.
  如有需要,请致电18165379690 或发送邮件至   jidian@xidian.edu.cn
