[STM32F3] STM32F302的USART1用不了,求助
3117|12
 楼主| 红木甲板 发表于 2014-8-15 15:18 | 显示全部楼层 |阅读模式
串口配置代码如下
  1. void uart_init(uint32_t bound)
  3.     GPIO_InitTypeDef GPIO_InitStructure;
  4.     USART_InitTypeDef USART_InitStructure;
  5.     NVIC_InitTypeDef NVIC_InitStructure;
  6.
  7.     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);//使能A口时钟
  8.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_SYSCFG,ENABLE);//使能串口1时钟
  9.
  10.     //USART_DeInit(USART1);
  11.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
  12.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  13.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; //复用
  14.     GPIO_InitStructure.GPIO_OType =GPIO_OType_PP ;        //推挽输出
  15.         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  16.         GPIO_PinAFConfig(GPIOA, GPIO_Pin_9, GPIO_AF_7);//USART1串口复用
  17.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  18.
  19.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;        //PA.10
  20.         //GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;//输入
  21.         //GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;//浮空
  22.         GPIO_PinAFConfig(GPIOA, GPIO_Pin_10, GPIO_AF_7);//USART1串口复用
  23.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  24.
  25.
  26.
  27.
  28.         USART_StructInit(&USART_InitStructure);
  29.         USART_InitStructure.USART_BaudRate = bound;//波特率
  30.         USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
  31.         USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
  32.         USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
  33.         USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;        //收发模式
  34.         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
  35.     USART_Init(USART1, &USART_InitStructure); //初始化串口
  36.
  37.
  38. #if EN_USART1_RX                  //如果使能了接收
  39.    //Usart1 NVIC 配置
  40.     NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  41.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
  42.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子优先级3
  43.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
  44.         NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
  45.
  46.     USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断
  47. #endif
  48.     USART_Cmd(USART1, ENABLE);                    //使能串口
  49.
  50. }
串口1发不出来也接收不到,是什么地方配置不对?求大神帮忙
zhangkuigang 发表于 2014-8-15 16:41 | 显示全部楼层
bound 没给具体值得话,是0,给各数9600试试
 楼主| 红木甲板 发表于 2014-8-15 16:43 | 显示全部楼层
bound作为入口参数的,我给的9600
gxhghost001 发表于 2014-8-15 17:00 | 显示全部楼层
pin 10  配置错误了
 楼主| 红木甲板 发表于 2014-8-15 17:02 | 显示全部楼层
pin 10  配置错误了
那两行注释和没注释都出不来
mmuuss586 发表于 2014-8-15 19:59 | 显示全部楼层
其中2句,改成下面的看看:
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_USART1);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource10, GPIO_AF_USART1);
 楼主| 红木甲板 发表于 2014-8-18 08:35 | 显示全部楼层
其中2句,改成下面的看看:
        GPIO_PinAFCo ...
库函数里面找不到GPIO_AF_USART1定义
SUNKE9 发表于 2014-8-18 09:18 | 显示全部楼层
楼上和你用的固件库不是一个,用你的固件库应该是GPIO_AF_x,这里的x需要到硬件手册里去查,看USART1对应的是几。
 楼主| 红木甲板 发表于 2014-8-18 10:56 | 显示全部楼层
楼上和你用的固件库不是一个,用你的固件库应该是GPIO_AF_x,这里的x需要到硬件手册里去查,看USART1对应 ...
恩,F30x的库就是GPIO_AF_7,我都查过了
gxhghost001 发表于 2014-8-18 12:04 | 显示全部楼层
那两行注释和没注释都出不来
  /* Configure USART Tx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = COM_TX_PIN[COM];
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_Init(COM_TX_PORT[COM], &GPIO_InitStructure);
  /* Configure USART Rx as alternate function push-pull */
  GPIO_InitStructure.GPIO_Pin = COM_RX_PIN[COM];
  GPIO_Init(COM_RX_PORT[COM], &GPIO_InitStructure);
这个是库文件写的,你的PA10 的写法,应该是F1系列库文件的写法。
 楼主| 红木甲板 发表于 2014-8-18 13:24 | 显示全部楼层
  GPIO_InitStructure.GPIO_Pin = COM_TX_ ...
所以那两行注释掉了啊,PA9 和PA10 GPIO配置是一样的了
gxhghost001 发表于 2014-8-18 16:44 | 显示全部楼层
你是怎么测试usart 的?先测试发送吧,可以先不管中断
 楼主| 红木甲板 发表于 2014-8-19 11:56 | 显示全部楼层
找到问题了,GPIO_PinAFConfig(GPIOA, GPIO_Pin_9, GPIO_AF_7);//USART1串口复用
应该是GPIO_PinAFConfig(GPIOA, GPIO_PinSource_9, GPIO_AF_7);//USART1串口复用
