[FPGA] VHDL 1602 第二行只显示点阵
2016|2
 楼主| kids_calamus 发表于 2014-8-27 11:24 | 显示全部楼层 |阅读模式
第一行显示正常,第二行显示是点阵
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LCD1602_1 is
Port ( CLK : in std_logic;
        Reset : in std_logic;
        LCD_RS : out std_logic; --寄存器选择信号
        LCD_RW : out std_logic; --液晶读写信号
        LCD_EN : out std_logic; --液晶时钟信号
        LCD_Data : out std_logic_vector(7 downto 0)); --液晶数据信号
end LCD1602_1;
architecture Behavioral of LCD1602_1 is
type state is (set_dlnf,set_cursor,set_dcb,set_cgram,write_cgram,set_ddram,write_LCD_Data);
signal Current_State:state;
signal Clk_Out : std_logic;
signal LCD_Clk : std_logic;
begin
process(CLK)--分频进程,CLK输入,CLK_Out输出,50MHz输入,125Hz输出,8ms
  variable n1:integer range 0 to 19999;
   begin
    if rising_edge(CLK) then
     if n1<19999 then n1:=n1+1;
      else n1:=0;
           Clk_Out<=not Clk_Out;
     end if;
    end if;
end process;
LCD_RW <= '0' ; --RW='0';写入设置
LCD_EN <= Clk_Out ; --用125Hz作为LCD的使能,也作为LCD的时钟
LCD_Clk <= Clk_Out; --用125Hz作为LCD的时钟
process(LCD_Clk,Reset,Current_State) --状态机控制显示
variable cnt1: std_logic_vector(4 downto 0):="00000";
begin
  if Reset='0'then Current_State<=set_dlnf; -- Reset就清屏,Reset接出用一个按钮作为复位按键即可,按下就为'0'复位。
                   cnt1:="11110";
--                   LCD_RS<='0';
  elsif rising_edge(LCD_Clk) then Current_State <= Current_State ; --LCD_RS <= '0';
     case Current_State is
      when set_dlnf=> LCD_RS<='0';cnt1:="00000";
                      LCD_Data<="00000001";  --  /*清除显示*/ 清屏指令
                      Current_State<=set_cursor;
      when set_cursor=> LCD_RS<='0';LCD_Data<="00111000";--/*设置8位格式,2行,5*7*/
                        Current_State<=set_dcb;
      when set_dcb=>  LCD_RS<='0';LCD_Data<="00001100";   --/*整体显示,关光标,不闪烁*/
                      Current_State<=set_cgram;
      when set_cgram=> LCD_RS<='0';LCD_Data<="00000110";  --/*显示移动格式,看最后两位,10表示光标右移
                       Current_State<=set_ddram;
      when set_ddram=> LCD_RS<='0';
                IF CNT1<"01111" THEN CNT1:=CNT1+1;         --主体显示,写显示地址DDRam(RS='0')
                       ELSE CNT1:="00000";
                       END IF;
                       IF CNT1<="01111" THEN LCD_Data <="11000000"+cnt1;
                       END IF;
                       Current_State<=write_cgram;
                when write_cgram=> LCD_RS<='1';    --主体显示,写显示内容
                         LCD_Data<="01010000" +cnt1;
                         Current_State<=write_LCD_Data;
      when write_LCD_Data=> LCD_RS<='0';LCD_Data<="00000000";
      when others => null;
     end case;
   end if;
end process;
end Behavioral;
gaochy1126 发表于 2014-9-1 23:16 | 显示全部楼层
有可能是亮度电阻的问题
gaochy1126 发表于 2014-9-1 23:17 | 显示全部楼层
看看你的电路有问题吗
