编译提示内存不足
994|2
 楼主| acer4736 发表于 2014-8-29 13:15 | 显示全部楼层 |阅读模式
"../28027_RAM_lnk.cmd", line 114: error #10099-D: program will not fit into available memory.  placement with alignment/blocking fails for section ".text" size 0x975 page 0.  Available memory ranges:
   PRAML0       size: 0x900        unused: 0x900        max hole: 0x900
error #10010: errors encountered during linking;
PRAML0     : origin = 0x008000, length = 0x000900
这段改大一点可以吗?
 楼主| acer4736 发表于 2014-8-29 13:16 | 显示全部楼层
C2000的
jxmzzr 发表于 2014-9-5 15:57 | 显示全部楼层
看一下map文件,PRAML0的使用情况.
