[Atmel]
ATMEL - ATEVK1100评估板
1008|0
ATMEL - ATEVK1100
The ATEVK1100 is an evaluation kit and development system for Atmel 32bit AVR UC3A microcontrollers. The kit is equipped with a rich set of peripherals and memory to make it easy to access the full potential of 32bit AVR UC3A devices. The device is preloaded with an application, called the AT32UC3A control panel. The AVR32 toolchain is a collection of tools that are required to be able to work with the AVR ONE. It contains command-line tools for controlling the AVR ONE, and tools to compile code for the AVR32 MCUs. The series features high connectivity with USB OTG, Ethernet MAC and SDRAM interfaces. These features combined with fast flash and large internal SRAM make it ideally suited for data intensive applications. AVR UC3 A0/A1 devices are particularly well suited for applications requiring Ethernet or USB connectivity and high computing performance.
  • Supports the AT32UC3A
  • Ethernet port
  • Light, temperature, potentiometer sensors
  • 4x20 blue LCD (PWM adjustable backlight)
  • Connectors for JTAG, Nexus, USART, USB 2.0, TWI, SPI
  • SD and MMC card reader
63177.pdf (695.18 KB)
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2400
