[i.MX] 出错啦!求解答啊
1162|4
 楼主| 小李菜刀 发表于 2014-9-11 17:52 | 显示全部楼层 |阅读模式
+ cd busybox-1.15.0
+ PKG_BUSYBOX_PRECONFIG=busybox.config
+ '[' -f /home/lijing/freescale/ltib/config/platform/imx/busybox.config ']'
+ cp /home/lijing/freescale/ltib/config/platform/imx/busybox.config .config
+ '[' -n '' -o -n '' ']'
+ make config 'HOSTCC=ccache /usr/bin/gcc -B/usr/bin/'
+ yes ''
Makefile:422: *** mixed implicit and normal rules.  Stop.
error: Bad exit status from /home/lijing/freescale/ltib/tmp/rpm-tmp.88423 (%build)
RPM build errors:
Build time for busybox: 5 seconds
Failed building busybox
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Thu Sep 11 01:32:06 2014
Ended:   Thu Sep 11 02:06:07 2014
Elapsed: 2041 seconds
These packages failed to build:
busybox
Build Failed
Exiting on error or interrupt
运行./ltib报错了
 楼主| 小李菜刀 发表于 2014-9-11 17:53 | 显示全部楼层
求大神解答啊,前面一路坎坷走过来眼看就要成功,等了半个小时,啪!出错了
FSL_TICS_Rita 发表于 2014-9-22 14:39 | 显示全部楼层
楼主你好,请问你帖中问题解决了吗?
很抱歉啊,帖子太多了,把你的这条给遗漏了。非常抱歉~~
FSL_TICS_Rita 发表于 2014-9-22 14:40 | 显示全部楼层
欢迎有问题继续在本论坛中创帖提问哈~~
