[Atmel] Atmel SAM-ICE仿真器介绍
1815|0
 楼主| ddllxxrr 发表于 2014-9-12 21:52 | 显示全部楼层 |阅读模式
这个仿真器给我的第一印象是JLINK。也不知道通用不?
Atmel SAM-ICE仿真器 适用于SAMA5, SAM3, SAM4, SAM7 和 SAM9 ARM系列。
Atmel SAMA5D3 [i18N - prefix removed]器件
说明
ATSAMA5D31
ARM Cortex-A5 processor-based embedded MPU, 536MHz, Linux support, FPU,LCDcontroller, 10/100 Ethernet, security
ATSAMA5D33
ARM Cortex-A5 processor-based embedded MPU, 536MHz, Linux support, FPU, LCDcontroller, gigabit Ethernet, security
ATSAMA5D34
ARM Cortex-A5 processor-based embedded MPU, 536MHz, Linux support, FPU, LCD controller, gigabit Ethernet, dual CAN, security
ATSAMA5D35
ARM Cortex-A5 processor-based embedded MPU, 536MHz, Linux support, FPU, dual Ethernet, dual CAN, security
Atmel SAM3S器件
说明
ATSAM3S1A
Cortex-M3 Microcontroller with 64KB Flash, USB, 48 Pins
ATSAM3S1B
Cortex-M3 Microcontroller with 64KB Flash, USB, 64 Pins
ATSAM3S1C
Cortex-M3 Microcontroller with 64KB Flash, USB, 100 Pins
ATSAM3S2A
Cortex-M3 Microcontroller with 128KB Flash, USB, 48 Pins
ATSAM3S2B
Cortex-M3 Microcontroller with 128KB Flash, USB, 64 Pins
ATSAM3S2C
Cortex-M3 Microcontroller with 128KB Flash, USB, 100 Pins
ATSAM3S4A
Cortex-M3 Microcontroller with 256KB Flash, USB, 48 Pins
ATSAM3S4B
Cortex-M3 Microcontroller with 256KB Flash, USB, 64 Pins
ATSAM3S4C
Cortex-M3 Microcontroller with 256KB Flash, USB, 100 Pins
ATSAM3S8B
Cortex-M3 Microcontroller with 512KB Flash, 64 Pins
ATSAM3S8C
Cortex-M3 Microcontroller with 512KB Flash, USB, 100 Pins
ATSAM3SD8B
Cortex-M3 Microcontroller with 2 x 256KB dual-bank Flash, USB, 64 pins
ATSAM3SD8C
Cortex-M3 Microcontroller with 2 x 256KB dual-bank Flash, USB, 100 Pins
OFDM-based PLC Solutions器件
说明
ATSAM4SP32A
首个基于 Cortex-M4 处理器、与 PRIME 兼容的、高度集成、高性能、低功耗的 PLC SoC
Atmel SAM3U器件
说明
ATSAM3U1C
Cortex-M3 Microcontroller with 64KB Flash, HS USB, 100 Pins
ATSAM3U1E
Cortex-M3 Microcontroller with 64KB Flash, HS USB, 144 Pins
ATSAM3U2C
Cortex-M3 Microcontroller with 128KB Flash, HS USB, 100 Pins
ATSAM3U2E
Cortex-M3 Microcontroller with 128KB Flash, HS USB, 144 Pins
ATSAM3U4C
Cortex-M3 Microcontroller with 256KB Flash, HS USB, 100 Pins
ATSAM3U4E
Cortex-M3 Microcontroller with 256KB Flash, HS USB, 144 Pins
Atmel SAM3N器件
说明
ATSAM3N00A
Cortex-M3 Microcontroller with 16KB Flash, 48 Pins
ATSAM3N00B
Cortex-M3 Microcontroller with 16KB Flash, 64 Pins
ATSAM3N0A
Cortex-M3 Microcontroller with 32KB Flash, 48 Pins
ATSAM3N0B
Cortex-M3 Microcontroller with 32KB Flash, 64 Pins
ATSAM3N0C
Cortex-M3 Microcontroller with 32KB Flash, 100 Pins
ATSAM3N1A
Cortex-M3 Microcontroller with 64KB Flash, 48 Pins
ATSAM3N1B
Cortex-M3 Microcontroller with 64KB Flash, 64 Pins
ATSAM3N1C
Cortex-M3 Microcontroller with 64KB Flash, 100 Pins
ATSAM3N2A
Cortex-M3 Microcontroller with 128KB Flash, 48 Pins
ATSAM3N2B
Cortex-M3 Microcontroller with 128KB Flash, 64 Pins
ATSAM3N2C
Cortex-M3 Microcontroller with 128KB Flash, 100 Pins
ATSAM3N4A
Cortex-M3 Microcontroller with 256KB Flash, 48 Pins
ATSAM3N4B
Cortex-M3 Microcontroller with 256KB Flash, 64 Pins
ATSAM3N4C
Cortex-M3 Microcontroller with 256KB Flash, 100 Pins
Atmel SAM3A器件
说明
ATSAM3A4C
Cortex-M3 Microcontroller with 2x128 KB Flash, HS USB, 100 Pins
ATSAM3A8C
Cortex-M3 Microcontroller with 2x256 KB Flash, HS USB, 100 Pins
Atmel SAM3X器件
说明
ATSAM3X4C
ATSAM3X4E
Cortex-M3 Microcontroller with 2x128 KB Flash, HS USB, 144 Pins
ATSAM3X8C
ATSAM3X8E
Cortex-M3 Microcontroller with 2x256 KB Flash, HS USB, 144 Pins
Atmel SAM4E [i18N - prefix removed]器件
说明
ATSAM4E16C
ARM® Cortex®-M4 microcontroller with 1MB Flash, IEEE Std 1588 10/100Mbps Ethernet MAC, CAN, FS USB, dual ADC/DAC, 100 pins
ATSAM4E16E
ARM® Cortex®-M4 microcontroller with 1MB Flash, IEEE Std 1588 10/100Mbps Ethernet MAC, dual CAN, FS USB, dual ADC/DAC, 144 pins
ATSAM4E8C
ARM® Cortex®-M4 microcontroller with 512KB Flash, IEEE Std 1588 10/100Mbps Ethernet MAC, CAN, FS USB, dual ADC/DAC, 100 pins
ATSAM4E8E
ARM® Cortex®-M4 microcontroller with 512KB Flash, IEEE Std 1588 10/100Mbps Ethernet MAC, dual CAN, FS USB, dual ADC/DAC, 144 pins
Atmel SAM4N [i18N - prefix removed]器件
说明
ATSAM4N16B
ARM® Cortex®-M4-based microcontroller with 1MB Flash, 80KB SRAM, 100MHz, serial communication peripherals, ADC/DAC, 64 pins
ATSAM4N16C
ARM® Cortex®-M4-based microcontroller with 1MB Flash, 80KB SRAM, 100MHz, serial communication peripherals, ADC/DAC, 100 pins
ATSAM4N8A
ARM® Cortex®-M4-based microcontroller with 512KB Flash, 64KB SRAM, 100MHz, serial communication peripherals, ADC, 48 pins
ATSAM4N8B
ARM® Cortex®-M4-based microcontroller with 512KB Flash, 64KB SRAM, 100MHz, serial communication peripherals, ADC/DAC, 64 pins
ATSAM4N8C
ARM® Cortex®-M4-based microcontroller with 512KB Flash, 64KB SRAM, 100MHz, serial communication peripherals, ADC/DAC, 100 pins
Atmel SAM4S器件
说明
ATSAM4SD32B
ARM®-based Cortex®-M4 core with 2MB dual-bank Flash, 160KB SRAM, USB, 64 Pins
ATSAM4SD32C
ARM®-based Cortex®-M4 core with 2MB dual-bank Flash, 160KB SRAM, USB, 100 Pins
ATSAM4SD16B
ARM®-based Cortex®-M4 core with 1MB dual-bank Flash, 160KB SRAM, USB, 64 Pins
ATSAM4SD16C
ARM®-based Cortex®-M4 core with 1MB dual-bank Flash, 160KB SRAM, USB, 100 Pins
ATSAM4SA16B
ARM®-based Cortex®-M4 core with 1MB Flash, 160KB SRAM, USB, 64 Pins
ATSAM4SA16C
ARM®-based Cortex®-M4 core with 1MB Flash, 160KB SRAM, USB, 100 Pins
ATSAM4S16B
ARM®-based Cortex®-M4 core with 1MB Flash, 128KB SRAM, USB, 64 Pins
ATSAM4S16C
ARM®-based Cortex®-M4 core with 1MB Flash, 128KB SRAM, USB, 100 Pins
ATSAM4S8B
ARM®-based Cortex®-M4 core with 512KB Flash, 128KB SRAM, USB, 64 Pins
ATSAM4S8C
ARM®-based Cortex®-M4 core with 512KB Flash, 128KB SRAM, USB, 100 Pins
Atmel SAM7S/SE器件
说明
AT91SAM7S16
ARM7TDMI Microcontroller with 16KB Flash, 48 Pins
AT91SAM7S161
ARM7TDMI Microcontroller with 16KB Flash, 64 Pins
AT91SAM7S32
ARM7TDMI Microcontroller with 32KB Flash, 48 Pins
AT91SAM7S321
ARM7TDMI Microcontroller with 32KB Flash, 64 Pins
AT91SAM7S64
ARM7TDMI Microcontroller with 64KB Flash, 64 Pins
AT91SAM7S128
ARM7TDMI Microcontroller with 128KB Flash, 64 Pins
AT91SAM7S256
ARM7TDMI Microcontroller with 256KB Flash, 64 Pins
AT91SAM7S512
ARM7TDMI Microcontroller with 512KB Flash, 64 Pins
AT91SAM7SE32
ARM7TDMI Microcontroller with 32KB Flash, 128 Pins
AT91SAM7SE256
ARM7TDMI Microcontroller with 256KB Flash, 128 Pins
AT91SAM7SE512
ARM7TDMI Microcontroller with 512KB Flash, 128 Pins
Legacy Products器件
说明
AT91M40800
ARM7TDMI Microcontroller with 8KB SRAM, 100 Pins
AT91M42800A
ARM7TDMI Microcontroller with 8KB on-chip SRAM, 144 Pins
AT91M55800A
ARM7TDMI Microcontroller with 8KB on-chip SRAM, 176 Pins
AT91R40008
ARM7TDMI Microcontroller with 256KB SRAM, 100 Pins
AT91RM9200
ARM920T Embedded Microprocessor Unit with USB host and Device, Ethernet, 208 and 256 Pins
AT91SAM9260
ARM926EJ Embedded Microprocessor Unit, 210MHz, FS USB, Ethernet, 208 & 217 Pins
AT91SAM9263
ARM926EJ Embedded Microprocessor Unit, 240MHz, LCD, USB, Ethernet and CAN, 324 Pins
Atmel SAM7X/XC器件
说明
AT91SAM7X128
ARM7TDMI Microcontroller with 128KB Flash, Ethernet, USB and CAN, 100 Pins
AT91SAM7X256
ARM7TDMI Microcontroller with 256KB Flash, Ethernet, USB and CAN, 100 Pins
AT91SAM7X512
ARM7TDMI Microcontroller with 512KB Flash, Ethernet, USB and CAN, 100 Pins
AT91SAM7XC128
ARM7TDMI Crypto Microcontroller with 128KB Flash, Ethernet, USB and CAN, 100 Pins
AT91SAM7XC256
ARM7TDMI Crypto Microcontroller with 256KB Flash, Ethernet, USB and CAN, 100 Pins
AT91SAM7XC512
ARM7TDMI Crypto Microcontroller with 512KB Flash, Ethernet, USB and CAN, 100 Pins
Atmel SAM7L器件
说明
AT91SAM7L128
ARM7TDMI Microcontroller with 128KB Flash, 128 and 144 Pins
AT91SAM7L64
ARM7TDMI Microcontroller with 64KB Flash, 128 and 144 Pins
Atmel SAM9XE器件
说明
AT91SAM9XE128
ARM926EJ Microcontroller with 128KB Flash, Ethernet, USB, 208 and 217 Pins
AT91SAM9XE256
ARM926EJ Microcontroller with 256KB Flash, Ethernet, USB, 208 and 217 Pins
AT91SAM9XE512
ARM926EJ Microcontroller with 512KB Flash, Ethernet, USB, 208 and 217 Pins
Atmel SAM9G器件
说明
AT91SAM9G46
ARM926EJ Embedded Microprocessor Unit, 400MHz, Hardware Encryption, DDR2/LPDDR, Dual EBI, 324 Pins
AT91SAM9G45
ARM926EJ Embedded Microprocessor Unit, 400MHz, DDR2/LPDDR, LCD, HS USB, 10/100 Ethernet, Dual EBI, 324 Pins
AT91SAM9G35
ARM926EJ Embedded Microprocessor Unit, 400MHz, LCD, Touchscreen, Ethernet, HS USB, LPDDR/DDR2/MLC NAND support, 217 Pins
AT91SAM9G25
ARM926EJ Embedded Microprocessor Unit, 400MHz, Ethernet, HS USB, LPDDR/DDR2/MLC NAND support, 217 and 247 Pins
AT91SAM9G20
ARM926EJ Embedded Microprocessor Unit, 400MHz, USB, Ethernet, 217 and 247 Pins
AT91SAM9G15
ARM926EJ Embedded Microprocessor Unit, 400MHz, LCD, Touchscreen, HS USB, LPDDR/DDR2/MLC NAND support, 217 Pins
AT91SAM9G10
ARM926EJ Embedded Microprocessor Unit, 266MHz, LCD, USB, 217 Pins
AT91SAM9261
ARM926EJ Embedded Microprocessor Unit, 190MHz, 160KB SRAM, LCD, USB, 217 Pins
Atmel SAM9X器件
说明
AT91SAM9X25
ARM926EJ Embedded Microprocessor Unit, 400MHz, Dual Ethernet and CAN, HS USB, LPDDR/DDR2/MLC NAND support, 217 Pins
AT91SAM9X35
ARM926EJ Embedded Microprocessor Unit, 400MHz, LCD, Touchscreen, Ethernet, Dual CAN, HS USB, LPDDR/DDR2/MLC NAND support, 217 Pins
Atmel SAM9R器件
说明
AT91SAM9R64
ARM926EJ Embedded Microprocessor Unit, 190MHz, HS USB, 144 Pins
AT91SAM9RL64
ARM926EJ Embedded Microprocessor Unit, 190MHz, LCD, HS USB, 217 Pins
Atmel SAM9M器件
说明
AT91SAM9M10
ARM926EJ Embedded Microprocessor Unit, 400MHz, DDR2/LPDDR, Video Decoder, LCD, HS USB, 10/100 Ethernet, Dual EBI, 324 Pins
AT91SAM9M11
ARM926EJ Embedded Microprocessor Unit, 400MHz, Hardware Encryption, Video Decoder, DDR2/LPDDR, Dual EBI, 324 Pins
Atmel SAM9N [i18N - prefix removed]器件
说明
AT91SAM9N12
ARM926EJ Embedded Microprocessor Unit, 400MHz, LCD, USB, LPDDR/DDR2/MLC NAND support, 217 Pins
AT91SAM9CN11
ARM926EJ Embedded Microprocessor Unit, 400MHz, Crypto engine, LCD, USB, LPDDR/DDR2/MLC NAND support, 217 Pins
AT91SAM9CN12
ARM926EJ Embedded Microprocessor Unit, 400MHz, Secure BootROM, Crypto engine, LCD, USB, LPDDR/DDR2/MLC NAND support, 217 Pins
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
