[技术求助] SmartRF Studio软件谁用过
1415|9
 楼主| jiahy 发表于 2014-9-19 12:13 | 显示全部楼层 |阅读模式
谁能讲哈SmartRF Studio软件的作用哇?
zhenykun 发表于 2014-9-19 12:13 | 显示全部楼层
调程序用的?
heweibig 发表于 2014-9-19 12:15 | 显示全部楼层
是不是可以直接改写芯片寄存器的值
wuhany 发表于 2014-9-19 12:15 | 显示全部楼层
也就相当于改了程序了吧
dengdc 发表于 2014-9-19 12:16 | 显示全部楼层
SmartRF® Studio is a Windows application made to evaluate and configure the Chipcon RF-ICs from Texas Instruments. This application must be used together with the applicable Evaluation Board. It is a very useful tool to explore and gain knowledge of the RF-IC products. This software will help the designers of radio systems to easily evaluate the RF-ICs at an early stage in the design process. It is especially useful for generation of the configuration data and for finding optimized external component values.
SmartRF® Studio covers all the Chipcon RF-ICs from TI.
http://focus.ti.com/lit/ug/swru070e/swru070e.pdf
 楼主| jiahy 发表于 2014-9-19 12:16 | 显示全部楼层
多谢啦,不过英文资料比较难懂,有没有用过这个软件的哇,谈一下体会
lizye 发表于 2014-9-19 12:18 | 显示全部楼层
smartrf自动生成相应配置寄存器值。
shimx 发表于 2014-9-19 12:18 | 显示全部楼层
对,它可以根据的你的设置的波特率,载波频率。。。。带宽。。。调制方式,自动生成相应寄存器的值使用非常方便
 楼主| jiahy 发表于 2014-9-19 12:19 | 显示全部楼层
多谢指点,明白了,哈哈~~
 楼主| jiahy 发表于 2014-9-19 12:20 | 显示全部楼层
结贴了
