[工具和软件] cw8.8 jtag连接不上p1020单板(已解决)
4581|5
 楼主| gao_changgang 发表于 2014-9-19 15:51 | 显示全部楼层 |阅读模式
开发板: p1020rdb-pd
codewarrior版本: 8.8
winxp
jtag: 000-75115 REV E 0921006 COP
说明:
使用code warrior flasher工具烧写flash时,提示错误
错误信息: please check your Jtag clock speed.
下面为log信息。
CCS: 0000        :        ccs_open
CCS:                :                ipaddr = 127.0.0.1
CCS:                :                port = 41475
CCS:                :                timeout = 100
CCS:                :                serverh = 0
CCS:                :        ccs_open; ccs_error = 0
CCS: 0000        :        ccs_get_connection_count
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :        ccs_get_connection_count; ccs_error = 0
CCS: 0000        :        ccs_available_connections
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :        ccs_available_connections; ccs_error = 0
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS: 0000        :        ccs_set_timeout
CCS:                :                serverh = 0
CCS:                :        ccs_set_timeout; ccs_error = 0
CCS: 0000        :        ccs_config_server
CCS:                :                serverh = 0
CCS:                :                cc = 0
CCS:                :                server_config = 0
CCS:                :                value = 2020
CCS:                :        ccs_config_server; ccs_error = 25
CCS:                :                Error message:
USB open failure
CCS: 0000        :        ccs_get_config_chain
CCS:                :                serverh = 0
CCS:                :                device_list: (size = 0)
CCS:                :        ccs_get_config_chain; ccs_error = 25
USB open failure
CCS: 0000        :        ccs_close
CCS:                :                serverh = 0
CCS:                :        ccs_close; ccs_error = 0
CCS: 0000        :        ccs_reset_to_debug
CCS:                :                serverh = 0
CCS:                :                cc = 0
CCS:                :        ccs_reset_to_debug; ccs_error = 7
Invalid handle
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS: 0000        :        ccs_delete_cc
CCS:                :                serverh = 0
CCS:                :                count = 0
CCS:                :        ccs_delete_cc; ccs_error = 7
Invalid handle
CCS:                :                serverh = 0
CCS:                :                port = 41475
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
CCS:                :                value = 2020
USB open failure
CCS:                :                serverh = 0
USB open failure
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                count = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                port = 41475
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
CCS:                :                value = 2020
USB open failure
CCS:                :                serverh = 0
USB open failure
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                count = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                port = 41475
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                count = 1
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
CCS:                :                value = 2020
USB open failure
CCS:                :                serverh = 0
USB open failure
CCS:                :                serverh = 0
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                cc = 0
Invalid handle
CCS:                :                serverh = 0
CCS:                :                count = 0
Invalid handle
CCS:                :                serverh = 0
please check your JTAG clock speed.
FSL_TICS_Robin 发表于 2014-9-22 08:48 | 显示全部楼层
楼主你好
建议你将此问题按照帖子   飞思卡尔申请样片与购买的论坛VIP通道开通了,小伙伴速来!   提交一个服务请求:
如果你尚未注册飞思卡尔官网账号,请先点击注册按钮:右侧图标完成注册。
如果你已有飞思卡尔官网账号,可以点击申请SR按钮:右侧图标提交一个服务请求。
最好使用英文详细描述一下遇到的问题,以便国内外工程师都能够帮助到你。
FSL_TICS_Robin 发表于 2014-9-26 09:58 | 显示全部楼层
楼主你好
由于论坛里没有P1020方面工程师,所以建议你提交技术服务请求以便获得技术支持。
如果你的问题解决了,能否配合我们按照本论坛中结帖方式操作结帖呢
谢谢:D
FSL_TICS_Lunmin 发表于 2014-9-26 14:08 | 显示全部楼层
你好,P1020RDB-PD相对较新,而CodeWarrior 8.8 officially的支持版本为P1020RDB Rev 1.0,且需安装补丁Servie Pack 1,具体可查看见飞思卡尔链接。
建议使用最新的CodeWarrior 10.4试一下,下载地址为可在飞思卡尔官网找到。
抱歉,我的权限还不能发链接。
FSL_TICS_Lunmin 发表于 2014-9-26 14:09 | 显示全部楼层
如果还有问题欢迎继续提问。
FSL_TICS_A 发表于 2014-10-8 09:39 | 显示全部楼层
楼主你好
请问此问题解决了吗,如果尚未解决欢迎继续讨论。
由于长时间未回帖,所以先把你的帖子标示成已解决了。
如果有空还请配合我们按照论坛置顶帖:本论坛中结帖方式 描述操作
