[i.MX] i.mx6dl烧写SD卡败
2181|15
 楼主| qigch 发表于 2014-9-26 17:12 | 显示全部楼层 |阅读模式
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceRemoveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device remove1
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent()-DEVICE_REMOVAL_EVT, hDevCanDeleteEvent has been set
ModuleID[2] LevelID[10]: delete MxHidDevice[00C53640]
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - DEVICE_ARRIVAL_EVT(\\?\USB#Vid_066f&Pid_37ff#5&36b1f8a7&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - end
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT(\\?\USB#Vid_066f&Pid_37ff#5&36b1f8a7&0&3#{a5dcbf10-6530-11d2-901f-00c04fb951ed})
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - DEVICE_ARRIVAL_EVT,[Msc,DiskDeviceClass] vid_066f&pid_37ff, not handled
ModuleID[2] LevelID[10]: DeviceManager::DevChangeWnd::OnDeviceChange() - VOLUME_ARRIVAL_EVT(I)
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT(I)
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice()  I
ModuleID[2] LevelID[1]: *** Error: 1, Drive: A:
ModuleID[2] LevelID[10]: DeviceTypeDisk--_devices size: 1
ModuleID[2] LevelID[10]: Volume--StorageDisk, Disk->_driveNumber:1, Volume->_diskNumber:1
ModuleID[2] LevelID[10]: DeviceTypeDisk--find Disk device: 00C53640
ModuleID[2] LevelID[10]: Device::hubIndex::getmsc, return the port index is: 3
ModuleID[2] LevelID[10]: VolumeDeviceClass::AddUsbDevice() successful I add to current list, retrycount: 0
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT-Disk(I), Hub:7-Port:3
ModuleID[2] LevelID[10]: DeviceManager::OnMsgDeviceEvent() - VOLUME_ARRIVAL_EVT, Notify
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume Arrive/Remove or Device Arrive/Remove
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, m_p_usb_port is not NULL, so only refresh
ModuleID[2] LevelID[10]: CmdOpreation[0]--OnDeviceChangeNotify, Volume/Device Arrive
ModuleID[2] LevelID[1]: CmdOpreation[0]--set m_hDeviceArriveEvent.
ModuleID[2] LevelID[10]: CmdOpreation[0]--WaitforEvents device arrive1
ModuleID[2] LevelID[10]: CmdOperation[0] device chagned and reset to state 1
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is send
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ tar xf $FILE
ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ sh mksdcard.sh /dev/mmcblk1
ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed
ModuleID[2] LevelID[10]: CmdOperation[0], current command executed failed, so SetEvent(hDevCanDeleteEvent)
FSL_TICS_Rita 发表于 2014-9-26 17:39 | 显示全部楼层
楼主你好,请问你使用的是哪块板子?自己设计的还是飞思卡尔的开发板?
FSL_TICS_Rita 发表于 2014-9-26 17:40 | 显示全部楼层
还有你往SD卡里写的是Linux还是android images呢?哪个版本的?
 楼主| qigch 发表于 2014-9-28 08:44 | 显示全部楼层
我根据MCIMX6Q-SDB板,画的开发板芯片焊接的IMX6DL的,使用Mfgtools-Rel-13.01.00_ER_MX6DL_UPDATER.tar.gz
FSL_TICS_Rita 发表于 2014-9-28 10:42 | 显示全部楼层
我根据MCIMX6Q-SDB板,画的开发板芯片焊接的IMX6DL的,使用Mfgtools-Rel-13.01.00_ER_MX6DL_UPDATER.tar.gz ...
楼主你好,在的吗?你参考MCIMX6Q-SDP板设计的话最好是使用芯片IMX6Q,如果你使用的芯片是IMX6DL的话,建议你参考板子MCIMX6DL-SDP设计的哈。
FSL_TICS_Rita 发表于 2014-9-28 10:43 | 显示全部楼层
还有你使用的烧写工具Mfgtools-Rel-13.01.00_ER_MX6DL_UPDATER.tar.gz是老的版本的了,建议你使用新的 版本的。
FSL_TICS_Rita 发表于 2014-10-9 16:20 | 显示全部楼层
楼主你好,请问你帖中问题是否已经解决了,如果已解决麻烦帮忙结帖啊,如果没有欢迎继续在这里讨论哈~~
 楼主| qigch 发表于 2014-11-27 19:22 | 显示全部楼层
你好,解决了,谢谢各位
FSL_TICS_Rita 发表于 2014-12-1 16:54 | 显示全部楼层
你好,解决了,谢谢各位
欢迎楼主有问题继续在本论坛中交流讨论哈~~
FSL_TICS_Rita 发表于 2014-12-1 16:56 | 显示全部楼层
对了,楼主问题解决的话,麻烦帮忙结帖哈,结帖方式:本论坛中结帖方式。
a151141 发表于 2015-4-14 19:40 | 显示全部楼层
你好,解决了,谢谢各位
请问楼主是怎么解决的?
我是MT 发表于 2015-4-14 21:11 来自手机 | 显示全部楼层
楼主是什么问题,可以跟大家分享一下
后会无期1 发表于 2015-4-15 20:42 来自手机 | 显示全部楼层
不知道楼主是怎么解决的
