[i.MX] Freeing init memory: 252K和EXT4-fs (mmcblk0p7): re-mounted. Opts: (null)
10353|23
 楼主| xiaoholmes 发表于 2014-9-28 08:35 | 显示全部楼层 |阅读模式
1、imx6板子运行到Freeing init memory: 252K就down掉了,但是不是每次都运行不了,多次android能够启动,大概连续10次有2到3次运行不了。Freeing init memory: 252K后面是挂载硬盘驱动的地方吗?板子上没有连接硬盘。
2、另外板子运行会出现EXT4-fs (mmcblk0p7): re-mounted,这里消耗时间很长,正常启动应该是没有
注:以下是部分信息,附件中是全部信息
DVFSdriver module loaded
regulator_init_complete:VDDD: incomplete constraints, leaving on
regulator_init_complete:VDDIO: incomplete constraints, leaving on
regulator_init_complete:VDDA: incomplete constraints, leaving on
snvs_rtcsnvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeinginit memory: 252K
init:cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
android_usb:already disabled
mtp_bind_config
adb_bind_config
adb_open
root@android:/# android_work: sent uevent USB_STATE=DISCONNECTED
android_work:sent uevent USB_STATE=CONNECTED
android_work:sent uevent USB_STATE=DISCONNECTED
EXT4-fs(mmcblk0p7): re-mounted. Opts: (null)
root@android:/ #android_work: sent uevent USB_STATE=DISCONNECTED
android_work: sent ueventUSB_STATE=CONNECTED
android_work: sent ueventUSB_STATE=DISCONNECTED
(正常启动没有红色这几行,非正常启动里面有这几行)
mcu_input_drv_opendo nothing inode:d1227690, file:d53fb460
android_work: sent uevent USB_STATE=CONNECTED
(正常启动有红色这几行,非正常启动里面没有这几行)
------------[cut here ]------------
WARNING:at arch/arm/plat-mxc/clock.c:63 clk_disable+0x44/0x8c()
clockenable/disable mismatch! clk  ipu1_clk
Moduleslinked in:
[<c0054e84>](unwind_backtrace+0x0/0x138) from [<c008f5dc>](warn_slowpath_common+0x4c/0x64)
[<c008f5dc>](warn_slowpath_common+0x4c/0x64) from [<c008f688>](warn_slowpath_fmt+0x30/0x40)
[<c008f688>](warn_slowpath_fmt+0x30/0x40) from [<c0070fa8>] (clk_disable+0x44/0x8c)
[<c0070fa8>](clk_disable+0x44/0x8c) from [<c02e6cfc>] (mxcfb_set_par+0x688/0x820)
[<c02e6cfc>](mxcfb_set_par+0x688/0x820) from [<c02d5420>] (fb_set_var+0x124/0x290)
[<c02d5420>](fb_set_var+0x124/0x290) from [<c02d5898>] (do_fb_ioctl+0x30c/0x5d0)
[<c02d5898>](do_fb_ioctl+0x30c/0x5d0) from [<c0140ba0>] (do_vfs_ioctl+0x80/0x54c)
[<c0140ba0>](do_vfs_ioctl+0x80/0x54c) from [<c01410a4>] (sys_ioctl+0x38/0x5c)
[<c01410a4>](sys_ioctl+0x38/0x5c) from [<c004d900>] (ret_fast_syscall+0x0/0x30)
---[ endtrace 08cc01c35d331764 ]---
panelsize = 800 x 480
pixel clk= 27000000
usespecial clk parent
panelsize = 1280 x 720
pixelclk = 74250000
tryipu internal clk
tryipu ext di clk
imx-ipuv3imx-ipuv3.1: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
ERROR:v4l2 capture: slave not found!
ERROR: v4l2 capture: slave not found!
ERROR: HDMI is not ready!
asoc: can't open platform imx-hdmi-soc-audio.0
panel size = 1280 x 720
pixel clk = 74250000
try ipu internal clk
try ipu ext di clk
(正常启动有红色这几行,非正常启动里面在上面)
[ep9851_task] EP9851: Signal Valid
[ep9851_task] EP9851: HDMI
[ep9851_task] EP9851: AVI Chg
EXT4-fs (mmcblk0p7): re-mounted. Optsnull)
//重新挂载,消耗时间很长,正常启动没有这条
[ep9851_task] EP9851: VMute Dsb
warning: `zygote' uses 32-bit capabilities (legacy support inuse)
//在此等待的时间大约有8秒
request_suspend_state:wakeup (3->0) at 26857698672 (1970-01-02 00:00:10.923768334 UTC)
cpufreq_interactive_input_connect:connect to imx-uart-input
cpufreq_interactive_input_connect:connect to max11801_ts
acc_open
acc_release
ehci_fsl_bus_resumebegins, Host 1
ehci_fsl_bus_resume ends, Host 1
in test mode, but singlestep NOT on
ehci_fsl_bus_resumebegins, DR
ehci_fsl_bus_resume begins, DR
init: sys_prop: permission denied uid:1003  name:service.bootanim.exit
(正常启动有上面这几行,非正常启动里面没有这几行)
ehci_fsl_bus_suspendbegins, Host 1
ehci_fsl_bus_suspendends, Host 1
init: sys_prop:permission denied uid:1003 name:service.bootanim.exit
(正常启动没有红色这一行,非正常启动里面有这一行)
root@android:/#
android启动失败.pdf
112.19 KB, 下载次数: 14
FSL_TICS_Rita 发表于 2014-9-28 09:57 | 显示全部楼层
楼主你好,请问你使用的是哪块板子呢?飞思卡尔的开发板还是自己设计的板子?
FSL_TICS_Rita 发表于 2014-9-28 09:58 | 显示全部楼层
还有你使用的是android的哪个版本?
 楼主| xiaoholmes 发表于 2014-9-28 11:11 | 显示全部楼层
你好,是公司自己设计的板子,不过是参考开发板设计的,android是4.2的版本
 楼主| xiaoholmes 发表于 2014-9-28 11:16 | 显示全部楼层
另外如果加上硬盘,每次都能启动,在Freeing init memory: 252K处停留2~3秒就能够启动,如果没有加上硬盘,就像上面所说的,大概连续10次有2到3次运行不了,并且在在Freeing init memory: 252K处停留至少5秒到7秒才能启动。请问这是啥原因呢?
FSL_TICS_Rita 发表于 2014-9-28 11:48 | 显示全部楼层
另外如果加上硬盘,每次都能启动,在Freeing init memory: 252K处停留2~3秒就能够启动,如果没有加上硬盘 ...
楼主你好,这里你是将images都烧写到哪个flash上的,SD卡还是别的呢?
FSL_TICS_Rita 发表于 2014-9-28 11:49 | 显示全部楼层
你这里加的是什么硬盘?
 楼主| xiaoholmes 发表于 2014-9-28 12:19 | 显示全部楼层
FSL工程师,你好,images都烧写到EMMC中的,这里加的是sata硬盘。
FSL_TICS_Rita 发表于 2014-9-28 14:29 | 显示全部楼层
既然你的images是烧写到emmc中的话,这里就不用添加硬盘了。你烧写images到emmc中,然后就是从emmc启动了。如果你要是想从SATA启动的话,就要有另外的操作了。
 楼主| xiaoholmes 发表于 2014-9-28 15:41 | 显示全部楼层
既然你的images是烧写到emmc中的话,这里就不用添加硬盘了。你烧写images到emmc中,然后就是从emmc启动了 ...
你好,我们是从emmc启动的,sata只是作为一个辅助的存储,不从SATA启动的,关键是现在不需要连接SATA硬盘,就会出现以上错误,停留在Freeing init memory: 252K启动不了,但又不是每次都启动不了。
 楼主| xiaoholmes 发表于 2014-9-28 15:44 | 显示全部楼层
我这边刚刚测试了一下,连续启动在第56次的时候,发现就启动不了了,停留在Freeing init memory: 252K处。
FSL_TICS_Rita 发表于 2014-9-28 16:53 | 显示全部楼层
你好,我们是从emmc启动的,sata只是作为一个辅助的存储,不从SATA启动的,关键是现在不需要连接SATA硬盘 ...
楼主你好,请问你u-boot中的环境参数是如何设定的,能否发给我看一下呢?
 楼主| xiaoholmes 发表于 2014-9-28 18:17 | 显示全部楼层
楼主你好,请问你u-boot中的环境参数是如何设定的,能否发给我看一下呢? ...
MX6Q SABRESD U-Boot > print
bootdelay=3
baudrate=115200
ipaddr=192.168.1.103
serverip=192.168.1.101
netmask=255.255.255.0
loadaddr=0x10800000
rd_loadaddr=0x11000000
netdev=eth0
ethprime=FEC0
splashimage=0x30000000
splashpos=m,m
lvds_num=1
stdin=serial
stdout=serial
stderr=serial
fastboot_dev=mmc3
bootcmd=booti mmc3
ethact=FEC0
另外在Device/fsl/sabresd_6dq/BoardConfig.mk文件中包含了内核参数
BOARD_KERNEL_CMDLINE :=console=ttymxc3,115200 init=/init video=mxcfb0:dev=lcd,AT070TN94-WVGA,if=RGB24,bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60,bpp=32 video=mxcfb2:off fbmem=10M fb0base=0x27b00000 vmalloc=400M androidboot.console=ttymxc3 androidboot.hardware=freescale
 楼主| xiaoholmes 发表于 2014-9-30 09:05 | 显示全部楼层
FSL工程师,你好,请问找到这个解决方法或者思路了吗?
bzw073 发表于 2014-9-30 10:05 | 显示全部楼层
至此按下
 楼主| xiaoholmes 发表于 2014-9-30 14:14 | 显示全部楼层
至此按下
你好,请问你有啥解决方法吗?
FSL_TICS_Rita 发表于 2014-10-8 16:38 | 显示全部楼层
你好,请问你有啥解决方法吗?
楼主你好,我看你u-boot的设置也是没有什么问题的,这里你测试的连续启动在第56次的时候,发现就启动不了了,停留在Freeing init memory: 252K处。请问在这里停留多长时间?还有你能否把这次停下来的**文件发给我一下呢,我看看。
 楼主| xiaoholmes 发表于 2014-10-9 09:28 | 显示全部楼层
楼主你好,我看你u-boot的设置也是没有什么问题的,这里你测试的连续启动在第56次的时候,发现就启动不了 ...
你好,就是一直停留在Freeing init memory: 252K,android系统启动不了,**文件在我上传的附件中。Freeing init memory: 252K上面的**文件都是一样的。
FSL_TICS_Rita 发表于 2014-10-9 11:37 | 显示全部楼层
你好,就是一直停留在Freeing init memory: 252K,android系统启动不了,**文件在我上传的附件中。Free ...
楼主你好,你给的附件打不开,你能重新发给我一下停留在Freeing init memory: 252K的**文件吗?
bestray 发表于 2014-10-12 11:04 | 显示全部楼层
我也是imx6自制板子运行到Freeing init memory: 244K就down掉了,spi flash启动uboot,sd卡下载系统镜像~~ 有解决办法吗???  据有人怀疑系统镜像烧的不对,但是有不对在哪里呢?哪里需要修改呢??
