[Atmel] AVR I2C程序
918|2
 楼主| ddllxxrr 发表于 2014-9-30 22:55 | 显示全部楼层 |阅读模式
avr I2C程序
#ifndef I2C_H
#define I2C_H
/* TWSR values (not bits) */
/* Master */
#define I2C_START    0x08
#define I2C_RESTART    0x10
/* Master Transmitter */
#define I2C_MT_SLA_ACK   0x18
#define I2C_MT_SLA_NACK   0x20
#define I2C_MT_DATA_ACK   0x28
#define I2C_MT_DATA_NACK 0x30
#define I2C_MT_ARB_LOST   0x38
/* Master Receiver */
#define I2C_MR_ARB_LOST   0x38
#define I2C_MR_SLA_ACK   0x40
#define I2C_MR_SLA_NACK   0x48
#define I2C_MR_DATA_ACK   0x50
#define I2C_MR_DATA_NACK 0x58
/* Slave Transmitter */
#define I2C_ST_SLA_ACK    0xA8
#define I2C_ST_ARB_LOST_SLA_ACK 0xB0
#define I2C_ST_DATA_ACK    0xB8
#define I2C_ST_DATA_NACK   0xC0
#define I2C_ST_LAST_DATA   0xC8
/* Slave Receiver */
#define I2C_SR_SLA_ACK     0x60
#define I2C_SR_ARB_LOST_SLA_ACK   0x68
#define I2C_SR_GCALL_ACK    0x70
#define I2C_SR_ARB_LOST_GCALL_ACK 0x78
#define I2C_SR_DATA_ACK     0x80
#define I2C_SR_DATA_NACK    0x88
#define I2C_SR_GCALL_DATA_ACK   0x90
#define I2C_SR_GCALL_DATA_NACK   0x98
#define I2C_SR_STOP      0xA0
/* Misc */
#define I2C_NO_INFO    0xF8
#define I2C_BUS_ERROR   0x00
* The lower 3 bits of TWSR are reserved on the ATmega163.
* The 2 LSB carry the prescaler bits on the newer ATmegas.
#define I2C_STATUS_MASK (_BV(TWS7)|_BV(TWS6)|_BV(TWS5)|_BV(TWS4)|_BV(TWS3))
#define I2C_STATUS   (TWSR & I2C_STATUS_MASK)
* R/~W bit in SLA+R/W address field.
#define I2C_READ   1
#define I2C_WRITE   0
#define I2CStart()      (TWCR=(1<<TWINT)|(1<<TWSTA)|(1<<TWEN))
#define I2CStop()       (TWCR=(1<<TWINT)|(1<<TWSTO)|(1<<TWEN))
#define I2CWaitAck() {while(!(TWCR&(1<<TWINT)));}
#define I2CChkAck()   (TWSR&0xf8)      //check ack
#define I2CSendAck() (TWCR|=(1<<TWEA))
#define I2CSendNoAck() (TWCR&=~(1<<TWEA))
#define I2CSendByte(x) {TWDR=(x);TWCR=(1<<TWINT)|(1<<TWEN);}
#define I2CRcvNckByte() (TWCR=(1<<TWINT)|(1<<TWEN))
#define I2CRcvAckByte() (TWCR=(1<<TWINT)|(1<<TWEN)|(1<<TWEA))
/* For Program */
#define I2C_Stop()   I2CStop()
#define I2C_SendAck() I2CSendAck()
#define I2C_SendNoAck() I2CSendNoAck()
#define I2C_WaitAck() I2CWaitAck()
/* I2C Config */
#define I2C_ERR    0
#define I2C_CRR    1
函数名称:I2C Start
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_Start()
I2CStart();
I2CWaitAck();
if( I2CChkAck()!=I2C_START )
   return I2C_ERR;
return I2C_CRR;
函数名称:I2C ReStart
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_Restart()
I2CStart();
I2CWaitAck();
if( I2CChkAck()!=I2C_RESTART )
   return I2C_ERR;
return I2C_CRR;
函数名称:发送 7位 器件写地址: XXXX XXX0
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_SendWrDAdr(unsigned char wrDAdr)
I2CSendByte(wrDAdr);    //设置 器件写地址
I2CWaitAck();
if( I2CChkAck()!=I2C_MT_SLA_ACK )
   return I2C_ERR;
return I2C_CRR;
函数名称:发送 10位 器件写地址: 1111 0XX0, XXXX XXXX
函数功能:
注意事项:
提示说明:兼容 发送 7位 器件写地址: XXXX XXX0
输     入:
返     回:
unsigned char I2C_SendWrDAdr_(unsigned int wrDAdr)
if( wrDAdr&0xF000 == 0xF000 ) //判断是否为 10位 器件地址
   if( I2C_SendWrDAdr((unsigned char )wrDAdr>>8)==I2C_ERR ) //设置 (高位)器件写地址
    return I2C_ERR;
if( I2C_SendWrDAdr( (unsigned char)wrDAdr )==I2C_ERR ) //设置 (低位)器件写地址
   return I2C_ERR;
return I2C_CRR;
函数名称:发送 7位 器件读地址: XXXX XXX1
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_SendRdDAdr(unsigned char rdDAdr)
I2CSendByte(rdDAdr);    //设置 器件读地址
I2CWaitAck();
if( I2CChkAck()!=I2C_MR_SLA_ACK )
   return I2C_ERR;
return I2C_CRR;
函数名称:发送 10位 器件读地址: 1111 0XX0, XXXX XXXX
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_SendRdDAdr_(unsigned char rdDAdr)
if( rdDAdr&0xF000 == 0xF000 ) //判断是否为 10位 器件地址
   if( I2C_SendWrDAdr( (unsigned char)rdDAdr>>8 )==I2C_ERR ) //设置 (高位)器件读地址
    return I2C_ERR;
if( I2C_SendWrDAdr( (unsigned char)rdDAdr )==I2C_ERR ) //设置 (低位)器件读地址
   return I2C_ERR;
return I2C_CRR;
函数名称:I2C发送数据
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_SendDat(unsigned char configDat)
I2CSendByte(configDat);
I2CWaitAck();
if( I2CChkAck()!=I2C_MT_DATA_ACK )
   return I2C_ERR;
return I2C_CRR;
函数名称:I2C接收数据且不产生应答
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_RcvNAckDat(unsigned char *pRdDat)
I2CRcvNckByte();
I2CWaitAck();
if( I2CChkAck()!=I2C_MR_DATA_NACK )
   return I2C_ERR;
*pRdDat=TWDR;
return I2C_CRR;
函数名称:I2C接收数据且产生应答
函数功能:
注意事项:
提示说明:
输     入:
返     回:
unsigned char I2C_RcvAckDat(unsigned char *pRdDat)
I2CRcvAckByte();
I2CWaitAck();
if( I2CChkAck()!=I2C_MR_DATA_ACK )
   return I2C_ERR;
*pRdDat=TWDR;
return I2C_CRR;
函数名称:I2C写器件,写一个数据
函数功能:
注意事项:
提示说明:
输     入:wrDAdr: write device-address 写器件地址
    wordAdr: word address 字地址
    dat: data 数据
返     回:
unsigned char I2C_Write(unsigned int wrDAdr,unsigned char wordAdr,unsigned char dat)
if( I2C_Start()==I2C_ERR )
   return I2C_ERR;
if( I2C_SendWrDAdr_(wrDAdr)==I2C_ERR )
   return I2C_ERR;
if( I2C_SendDat(wordAdr)==I2C_ERR )
   return I2C_ERR;
if( I2C_SendDat(dat)==I2C_ERR )
   return I2C_ERR;
I2C_Stop();
return I2C_CRR;
函数名称:I2C写器件,写N个数据
函数功能:
注意事项:
提示说明:
    *pWrDat: p->write data 写入数据指针
    num: number 写入数据个数
返     回:
unsigned char I2C_Write_(unsigned int wrDAdr,unsigned char wordAdr,
       unsigned char *pWrDat,unsigned char num)
     unsigned char i;
   return I2C_ERR;
   return I2C_ERR;
   return I2C_ERR;
for(i=0;i<num;i++)
   if( I2C_SendDat(*(pWrDat++))==I2C_ERR )
   return I2C_ERR;
I2C_Stop();
return I2C_CRR;
函数名称:I2C读器件,读一个数据
函数功能:
注意事项:
提示说明:
    rdDAdr: read device-address 读器件地址
    *pRdDat: p->read data 读取数据指针
返     回:
unsigned char I2C_Read(unsigned int wrDAdr,unsigned char wordAdr,
      unsigned char rdDAdr,unsigned char *pRdDat)
   return I2C_ERR;
   return I2C_ERR;
   return I2C_ERR;
if( I2C_Restart()==I2C_ERR )
   return I2C_ERR;
if( I2C_SendRdDAdr(rdDAdr)==I2C_ERR )
   return I2C_ERR;
if( I2C_RcvNAckDat(pRdDat)==I2C_ERR )
   return I2C_ERR;
I2C_Stop();
return I2C_CRR;
函数名称:I2C读器件,读N个数据
函数功能:
注意事项:
提示说明:
    rdDAdr : read device-address 读器件地址
    num: number 读取数据个数
返     回:
unsigned char I2C_Read_(unsigned int wrDAdr,unsigned char wordAdr,
       unsigned char rdDAdr,unsigned char *pRdDat,unsigned char num)
   unsigned char i;
   return I2C_ERR;
   return I2C_ERR;
   return I2C_ERR;
   return I2C_ERR;
   return I2C_ERR;
for(i=0;i<num-1;i++)
   if( I2C_RcvAckDat(pRdDat+i)==I2C_ERR )
    return I2C_ERR;
if( I2C_RcvNAckDat(pRdDat+i)==I2C_ERR )
    return I2C_ERR;
I2C_Stop();
return I2C_CRR;
#endif
colinh 发表于 2014-10-16 17:04 | 显示全部楼层
赞,正好在用,收下了,学习下,感谢楼主!
 楼主| ddllxxrr 发表于 2014-10-16 20:42 | 显示全部楼层
:handshake
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
