[Atmel] Atmel也出Cortex-M7样品了
1712|0
 楼主| ddllxxrr 发表于 2014-10-2 21:05 | 显示全部楼层 |阅读模式
爱特梅尔公司样品高性能ARM Cortex-M7-based单片机使新一代的物联网、工业和汽车应用
——扩大Atmel |智能组合,首先设备运行300 mhz,包括384千字节存储器配置紧密耦合的内存(TCM)或系统内存和2兆字节片上闪存。
——结合以太网AVB和媒体磅外设与Cortex-M7 DSP扩展使他们适合汽车连接和音频应用程序
原文如下:
SAN JOSE, Calif., Oct. 2, 2014 /PRNewswire/ -- Today at ARM® TechCon 2014,Atmel Corporation (NASDAQ: ATML), a global leader in microcontroller (MCU) and touch solutions, announced the development of a new family of Atmel® | SMART™ ARM Cortex-M7-based MCUs that are sampling to select customers now. Broadening Atmel's current MCU/MPU portfolio, the family is well positioned between Atmel's Cortex®-M-based MCUs and Cortex-A-based MPUs enabling designers to select from a greater range of processing solutions. The new devices will address high-growth markets including the Internet of Things (IoT) and wearables, as well as automotive and industrial applications that require both high performance and power efficiency.
The Atmel® | SMART Cortex-M-based MCUs allow customers to scale-up performance, SRAM and system functionality, while keeping the Cortex-M class ease-of-use and maximizing software reuse. The first devices will run up to 300MHz, with up to 384kByte SRAM configurable as Tightly Coupled Memory (TCM) or System Memory, and up to 2Mbyte on-chip Flash. They will be comprised of three series: general purpose, connectivity and automotive-qualified.
"As one of the first ARM licensees, we are excited to add the Cortex-M7 core to our already broad portfolio of MCUs and MPUs," said Jacko Wilbrink, sr. marketing director, Atmel Corporation. "The new Cortex-M7-based MCUs leverage our advanced peripherals and flexible SRAM architecture for higher performance applications, while keeping the Cortex-M class ease-of-use. This new addition enables our customers to select from an even larger portfolio of Atmel | SMART ARM-based MCUs to optimize system designs from consumer IoT devices to automotive applications."
"Atmel's new family of microcontrollers helps to bridge the gap between existing microprocessors and highly-efficient microcontrollers on the market," said Noel Hurley, general manager, CPU group. "The ARM Cortex-M7 core drives innovation and pushes the performance envelope for embedded devices."
All devices come standard with high-speed USB On-the-Go (OTG) and on-chip high-speed USB PHY, the connectivity series offers 10/100 TBase Ethernet MAC and Dual CAN-FD from Bosch. The automotive series offers Ethernet AVB support and Media LB, which when combined with the Cortex-M7 DSP extensions, make the series ideal for infotainment connectivity and audio applications.
Atmel is working closely with the ARM ecosystem partners on development tool support and RTOS BSPs for the new Atmel | SMART Cortex-M7-based MCUs. In addition, Atmel will offer complete support for this new MCU family on Atmel Studio and Atmel ICE. A comprehensive set of peripheral drivers and examples will be provided as well as Xplained evaluation kits.
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
