基于STM32的ADS8341驱动程序
2581|2
 楼主| 睡着思考 发表于 2014-10-9 17:07 | 显示全部楼层 |阅读模式
基于STM32的ADS8341驱动程序怎么编写啊  本人菜鸟 求高手帮助。
dirtwillfly 发表于 2014-10-9 17:11 | 显示全部楼层
这问题让人没法回答。
一般来说,要根据你的电路图和ADS8341datasheet上提供的通讯时序进行编写
 楼主| 睡着思考 发表于 2014-10-11 16:07 | 显示全部楼层
求高手解惑 不胜感激。
/*                                        ADS8341操作函数                                                   */
#define                ADPORT                GPIOB
//#define                ADReset                GPIO_Pin_3
#define                DClk                GPIO_Pin_8
#define                Dout                GPIO_Pin_10
#define                Din                        GPIO_Pin_9
//#define                DRTY                GPIO_Pin_7
#define         DClk0()            GPIO_ResetBits(GPIOB,DClk)
#define         DClk1()            GPIO_SetBits  (GPIOB,DClk)
#define         Din0()             GPIO_ResetBits(GPIOB,Din)
#define         Din1()             GPIO_SetBits  (GPIOB,Din)
extern void delay_nus(unsigned long n);
extern void delay_nms(unsigned long n);
void WriteByte8341(unsigned char x)
        unsigned char i;
        delay_nus(50);
        DClk1();
        delay_nus(100);
        for (i=0; i<8; i++)
                Din0();
                DClk0();
                delay_nus(10);
                if( (x & 0x94) )
                        Din1();
                        delay_nus(100);
                else
                        Din0();
                        delay_nus(100);
//                AdDin =(bit) (x & 0x80);
                DClk1();
                delay_nus(100);
                x <<=1;
        Din0();
        delay_nus(1000);
unsigned int ReadWord8341(void)
        unsigned char i;
        unsigned int x=0 ;
        delay_nus(100);
        DClk1();
        delay_nus(100);
    for (i = 0 ; i < 16 ; i++)
                DClk0();
                x<<=1;
                if(GPIO_ReadInputDataBit(GPIOB,Dout))
                         x |= 0x01;
                else
                delay_nus(100);
                DClk1();
                delay_nus(100);
        return x;
void Reset8341(void)
        unsigned char i;
//        GPIO_ResetBits(ADPORT,ADReset);
//        delay_nms(10);
        GPIO_SetBits  (ADPORT,Dout);
        delay_nms(300);
        for(i=0;i<35;i++)
                DClk0();
                delay_nus(10);
                Din1();
                delay_nus(90);
                DClk1();
                delay_nus(100);
        Din1();;;
        delay_nus(50);
void Init8341()                        //第一个端口初始化
        Reset8341();
        delay_nus(100);
        WriteByte8341(0x94);//选择操作时钟寄存器
//        delay_nus(100);
//        WriteByte8341(0x04);
//        delay_nus(100);
//        WriteByte8341(0x10);
//        delay_nus(100);
//        WriteByte8341(0x44);
//        delay_nus(100);
//void Init8341_2()            //第二个端口初始化
//        Reset8341();
//        WriteByte8341(0x21);//选择操作时钟寄存器
//        WriteByte8341(0x11);
unsigned int GetData8341()        //读取第一个通道
        return ( ReadWord8341() );
//unsigned int GetData8341_2() //读取第二个通道
//        WriteByte8341(0x39);
//        return ( ReadWord8341() );
///在主函数中只用了下面连个函数
Init8341();                                                //初始化ADS8341通道1
delay_nms(10);
Voltage =         GetData8341();
求高手解惑 不胜感激。
