【TI FAQ】如何在非标准频率下设置C2000 ECAN的波特率参数
1657|2
 楼主| Laspide 发表于 2014-10-16 09:18 | 显示全部楼层 |阅读模式
FAQ 标题:如何在非标准频率下设置C2000 ECAN的波特率参数?
FAQ 正文:在非标准频率下设置C2000 ECAN的波特率参数的例子。
Calculation of the CAN bit timing :
System clock                         f_sys = 24 MHz
System clock period            t_sys=1/f_sys = 41.666667 ns
BRP = 23
Desired bit rate is 125KBit/s, desired bit time is 8000 ns
CAN time quantum              tq = 24 * t_sys = 1000ns
Actual bit time = 8 * tq =  ~= 8000 ns
Actual bit rate is 124999.999bit/s ~= 125Kbit/s
CAN bus length = 10 m, with 5 ns/m signal delay time.
Propagation delay time : 2 * ( transceiver loop delay + bus line delay ) = 400 ns
Prop_Seg = 1 * tq = 1000ns > 400ns.
Sync_Seg = 1 tq .
Phase_seg1 + Phase_Seg2 = (8-2) tq = 6 tq
Phase_seg1 = 3 tq and Phase_Seg2 = 3 tq
SJW = (min(Phase_Seg1, 4)) tq = 3 tq
TSEG1 = (Prop_Seg + Phase_Seg1 - 1) = 3
TSEG2 = (Phase_Seg2 - 1) = 2
SJW_p = (SJW - 1) = 2
Clock tolerance df :
A: df < min(Phase_Seg1, Phase_Seg2) / (2 * (13*bit_time - Phase_Seg2))
B: df < SJW / (20 * bit_time)
A: df < 3/(2*(13*11-3)) = 3/280 = 1.0714%
B: df < 3/(20*11) = 3/220 = 1.3636%
dirtwillfly 发表于 2014-10-16 22:06 | 显示全部楼层
感谢你的支持,不过活动已经结束了
仙人球W 发表于 2015-8-21 14:06 | 显示全部楼层
