[i.MX]
MX6Q SDP SABRE 库路径问题(已解决)
935|5
我的账户|  楼主 | 2014-10-19 12:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
版主你好,请教下,我们工具链安装后,里面的库,具体是使用哪个,
我打个比方,d-2.13.so 到底用的是哪个,多谢了
./arm-fsl-linux-gnueabi/multi-libs/default/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/default/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv6/softfp/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv6/softfp/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/neon/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/neon/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/vfpv3/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/vfpv3/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/neon/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/neon/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/vfpv3/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/vfpv3/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/softfp/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/softfp/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/hard/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/hard/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/default/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/default/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv5/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv5/lib/ld-2.13.so
相关下载
FSL_TICS_Rita| | 2014-10-20 09:09 | 只看该作者
楼主你好,请问你是使用的哪个编译工具?LTIB还是Yocto?
我的账户|  楼主 | 2014-10-24 20:52 | 只看该作者
LTIB
FSL_TICS_Rita| | 2014-10-29 14:50 | 只看该作者
楼主你好,i.mx6q是cotex-a9的核,使用的是ARMv7的库。
FSL_TICS_Rita| | 2014-11-27 15:04 | 只看该作者
楼主你好,请问你本贴中的问题是否已经解决了?如果没有欢迎继续在这里讨论哈,如果已解决麻烦帮忙结帖哈,非常感谢~~
