[技术问题解答]
KL25的BUSCLK可以设置成自己想要的频率吗?
1145|2
FSL_TICS_ZJJ| | 2014-10-20 15:15 | 只看该作者
楼主你好!
不好意思,迟回复你了。
是可以修改BUSCLK的,但是需要满足如下要求:
The bus clock and flash clock frequency is divided from the system clock and is
programmable from a divide-by-1 through divide-by-8 setting. The bus clock and
flash clock must be programmed to 24 MHz or slower.
这点在我们的用户手册中写了。
