版主你好,请教下,我们工具链安装后,里面的库,具体是使用哪个,
我打个比方,d-2.13.so 到底用的是哪个,多谢了
./arm-fsl-linux-gnueabi/multi-libs/default/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/default/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv6/softfp/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv6/softfp/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/neon/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/neon/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/vfpv3/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/softfp/vfpv3/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/neon/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/neon/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/vfpv3/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/arm/hard/vfpv3/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/a9/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/a9/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/softfp/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/softfp/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/hard/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/thumb/hard/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/default/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv7-a/default/lib/ld-2.13.so
./arm-fsl-linux-gnueabi/multi-libs/armv5/lib/ld-linux.so.3
./arm-fsl-linux-gnueabi/multi-libs/armv5/lib/ld-2.13.so |
