[8/16-bit MCU] mc9s12G FLASH ecc读检测
1262|1
 楼主| caijun_2012 发表于 2014-10-30 21:51 | 显示全部楼层 |阅读模式
#define EepromStartAddress     0x0400
#define EepromEndAddress       0x0BFF
FCNFG =0X03; /*Force Double Bit Fault Detect*/
unsigned char g_uint8_EepGetByte(unsigned int b_u16_EepAddress)
    unsigned char ReturnData,test;
    if (b_u16_EepAddress<EepromStartAddress || b_u16_EepAddress>=EepromEndAddress ) {
        return 0;
    if(!FSTAT_CCIF) {               // Is reading from EEPROM possible?
        return 0;                   // If no then error
    ReturnData=(*(unsigned char volatile*)b_u16_EepAddress);
   asm("nop");
asm("nop");
asm("nop");
asm("nop");
test = FERSTAT;
if(FERSTAT&0x03)
{/*为什么每次读完检测ECC都有故障,查看读出数据有是正常地,请高手指教*/
      FERSTAT |= 0x03;
      return 0;
else
    return  ReturnData;
FSL_TICS_ZJJ 发表于 2014-10-31 10:26 | 显示全部楼层
楼主你好!
你读之前有没有检查这个故障状态标志是否已经置位,如果是,先把标志给清楚掉。
