[应用相关] 分享:stm32 USART的使用源程序
1075|2
 楼主| huangfeng33 发表于 2014-10-31 11:25 | 显示全部楼层 |阅读模式
#include "stm32f10x_lib.h"
#include"stdio.h"
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
/* RCC system reset(for debug purpose) */
RCC_DeInit();          //将外设RCC 寄存器重设为缺省值
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);//使能外部时钟
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();//等待外部时钟就绪
if(HSEStartUpStatus == SUCCESS)
   /* Enable Prefetch Buffer 启用预取缓冲器 */
   FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
   /* Flash 2 wait state FLASH设置2个等待周期*/
   FLASH_SetLatency(FLASH_Latency_2);
   /* HCLK(AHB时钟) = SYSCLK 设置AHB时钟*/
   RCC_HCLKConfig(RCC_SYSCLK_Div1);//AHB(Advanced High performance Bus)系统总线
                                                    //APB(Advanced Peripheral Bus)外围总线
   /* PCLK2 = HCLK PCLK2时钟=主时钟*/
   RCC_PCLK2Config(RCC_HCLK_Div1);
   /* PCLK1 = HCLK/2 PCLK1时钟为主时钟1/2*/
   RCC_PCLK1Config(RCC_HCLK_Div2);
   /* PLLCLK = 8MHz * 9 = 72 MHz 设置时钟为72M,设置PLL时钟源及倍频系数(<=72M)*/
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
   /* Enable PLL 使能PLL*/
   RCC_PLLCmd(ENABLE);
   /* Wait till PLL is ready */
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
   /* Select PLL as system clock source */
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
   /* Wait till PLL is used as system clock source */
   while(RCC_GetSYSCLKSource() != 0x08);
void USART_configuration(void)
   USART_InitTypeDef USART_InitStructure;
   USART_InitStructure.USART_BaudRate = 9600;
   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
   USART_InitStructure.USART_StopBits = USART_StopBits_1;
   USART_InitStructure.USART_Parity = USART_Parity_No;
   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
   USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
   USART_Init(USART1, &USART_InitStructure);
   USART_Cmd(USART1, ENABLE);
void USART_ClockInitconfiguration(void)
   USART_ClockInitTypeDef  USART_ClockInitStructuree;
   USART_ClockInitStructuree.USART_Clock = USART_Clock_Disable;
   USART_ClockInitStructuree.USART_CPOL = USART_CPOL_High;
   USART_ClockInitStructuree.USART_CPHA = USART_CPHA_1Edge;
   USART_ClockInitStructuree.USART_LastBit = USART_LastBit_Enable;
   USART_ClockInit(USART1, &USART_ClockInitStructuree);
void GPIO_configuration(void)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1  , ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
int main(void)
   unsigned char i,data;
   RCC_Configuration();
   GPIO_configuration();
   USART_ClockInitconfiguration();
   USART_configuration();
   data='A';
   for(i=0;i<30;i++)
USART_SendData(USART1, data);
data++;
while(USART_GetFlagStatus(USART1, USART_FLAG_TC) ==RESET)        ;
  return(1);
mmuuss586 发表于 2014-10-31 12:28 | 显示全部楼层
支持楼主分享;
zh113214 发表于 2014-11-1 12:59 | 显示全部楼层
表示赞一个!!!
