http://www.st.com/stonline/books/pdf/docs/4848.pdf<br />ts221 的marking 是221I<br />lm221 的marking 是221<br />所以应该是后者了.<br /><br />Order codes Part number Temperature range Package Packing Marking<br />LM211N -40°C, +105°C DIP8 Tube LM211N<br />LM211D/DT SO-8 Tube or tape & reel 211<br />LM311N 0°C, +70°C DIP8 Tube LM311<br />LM311D/DT SO-8 Tube or Tape & reel 311
