VLSI Solution Oy 推出支持多种格式解码和OGG格式编码的芯片
3625|0
 楼主| aivenk 发表于 2007-9-17 20:58 | 显示全部楼层 |阅读模式
VS1053&nbsp;–&nbsp;A&nbsp;multi-&nbsp;format&nbsp;high&nbsp;performance&nbsp;audio&nbsp;codec<br />Tampere,&nbsp;Finland,&nbsp;13th&nbsp;of&nbsp;September&nbsp;2007&nbsp;-&nbsp;VLSI&nbsp;Solution&nbsp;announced&nbsp;today&nbsp;the<br />VS1053&nbsp;audio&nbsp;decoder/encoder&nbsp;IC.<br />VS1053&nbsp;is&nbsp;the&nbsp;most&nbsp;advanced&nbsp;slave&nbsp;audio&nbsp;circuit&nbsp;of&nbsp;VLSI&nbsp;Solution's&nbsp;product&nbsp;family.&nbsp;In<br />addition&nbsp;to&nbsp;being&nbsp;able&nbsp;to&nbsp;decode&nbsp;MP1,&nbsp;MP2,&nbsp;MP3,&nbsp;WMA,&nbsp;WAV,&nbsp;IMA&nbsp;ADPCM,<br />General&nbsp;Midi&nbsp;1,&nbsp;Ogg&nbsp;Vorbis,&nbsp;LC-&nbsp;AAC&nbsp;and&nbsp;HE-&nbsp;AAC&nbsp;file&nbsp;formats,&nbsp;it&nbsp;can&nbsp;also&nbsp;record&nbsp;in<br />IMA&nbsp;ADPCM&nbsp;and&nbsp;Ogg&nbsp;Vorbis&nbsp;file&nbsp;formats.<br />The&nbsp;device&nbsp;features&nbsp;low&nbsp;power&nbsp;and&nbsp;high&nbsp;performance.&nbsp;The&nbsp;integrated&nbsp;DAC&nbsp;has&nbsp;100<br />dB&nbsp;SNR,&nbsp;thus&nbsp;it&nbsp;can&nbsp;accurately&nbsp;reproduce&nbsp;all&nbsp;industry&nbsp;standard&nbsp;formats.&nbsp;The<br />sophisticated&nbsp;HE-&nbsp;AAC&nbsp;decoder&nbsp;is&nbsp;able&nbsp;to&nbsp;provide&nbsp;high&nbsp;quality&nbsp;sound&nbsp;for&nbsp;low&nbsp;bit&nbsp;rate<br />internet&nbsp;streaming&nbsp;files.<br />The&nbsp;on-&nbsp;chip&nbsp;stereo&nbsp;ADC&nbsp;features&nbsp;over&nbsp;90&nbsp;dB&nbsp;SNR,&nbsp;thus&nbsp;providing&nbsp;high-&nbsp;quality<br />recording&nbsp;from&nbsp;the&nbsp;line&nbsp;out&nbsp;or&nbsp;headphone&nbsp;connectors&nbsp;of&nbsp;external&nbsp;music&nbsp;devices.&nbsp;For<br />recording,&nbsp;Ogg&nbsp;Vorbis&nbsp;encoder&nbsp;can&nbsp;be&nbsp;loaded&nbsp;into&nbsp;the&nbsp;customization&nbsp;RAM&nbsp;of&nbsp;the<br />device&nbsp;to&nbsp;achive&nbsp;near&nbsp;CD&nbsp;quality&nbsp;stereo&nbsp;sound&nbsp;at&nbsp;medium&nbsp;bit&nbsp;rates&nbsp;(100&nbsp;kbit/s),&nbsp;or<br />speech-&nbsp;quality&nbsp;mono&nbsp;sound&nbsp;at&nbsp;bitrates&nbsp;lower&nbsp;than&nbsp;20&nbsp;kbit/s.&nbsp;The&nbsp;Ogg&nbsp;Vorbis&nbsp;encoder<br />will&nbsp;be&nbsp;available&nbsp;for&nbsp;free&nbsp;download&nbsp;in&nbsp;October&nbsp;2007.<br />The&nbsp;device&nbsp;has&nbsp;16&nbsp;KiB&nbsp;of&nbsp;customization&nbsp;program&nbsp;RAM&nbsp;memory&nbsp;which&nbsp;is&nbsp;more&nbsp;than<br />three&nbsp;times&nbsp;the&nbsp;memory&nbsp;of&nbsp;VLSI's&nbsp;earlier&nbsp;audio&nbsp;codecs.&nbsp;The&nbsp;program&nbsp;RAM&nbsp;broadens<br />the&nbsp;capabilities&nbsp;of&nbsp;VS1053&nbsp;to&nbsp;include&nbsp;new&nbsp;audio&nbsp;applications&nbsp;such&nbsp;as&nbsp;echo<br />cancellation&nbsp;for&nbsp;mobile&nbsp;phone&nbsp;or&nbsp;VOIP.<br />VS1053&nbsp;contains&nbsp;VLSI&nbsp;Solution's&nbsp;proprietary&nbsp;EarSpeaker&nbsp;Spatial&nbsp;Processing<br />technology.&nbsp;This&nbsp;emulates&nbsp;a&nbsp;listening&nbsp;room&nbsp;to&nbsp;move&nbsp;music&nbsp;outside&nbsp;the&nbsp;listener's&nbsp;head<br />as&nbsp;if&nbsp;it&nbsp;would&nbsp;come&nbsp;from&nbsp;real&nbsp;loudspeakers.<br />The&nbsp;device&nbsp;runs&nbsp;with&nbsp;any&nbsp;external&nbsp;clock<br />between&nbsp;12&nbsp;and&nbsp;13&nbsp;MHz.&nbsp;This&nbsp;makes&nbsp;it<br />possible&nbsp;to&nbsp;use&nbsp;the&nbsp;USB&nbsp;or&nbsp;GSM&nbsp;clock<br />domains&nbsp;of&nbsp;an&nbsp;existing&nbsp;application.<br />VS1053&nbsp;is&nbsp;offered&nbsp;in&nbsp;LQFP-&nbsp;48<br />7x7x1.4mm&nbsp;RoHS&nbsp;compatible&nbsp;package.<br />Engineering&nbsp;samples&nbsp;and&nbsp;evaluation&nbsp;kit<br />are&nbsp;immediately&nbsp;available.&nbsp;Volume<br />production&nbsp;is&nbsp;expected&nbsp;to&nbsp;start<br />Q1/2008.<br /><br />www.vlsi.fi<br />索取样片:www.megadiy.com<br />
