[Atmel] 用AtmelStudio6.2跑mega16例程(48)双路双显ADC
1185|0
 楼主| ddllxxrr 发表于 2014-11-6 19:48 | 显示全部楼层 |阅读模式
ADC控制与状态寄存器A   ADCSRA 程序中其取值为0xE6(11100110),其最高位ADEN置位启动ADC,ADSC置位开始转换,ADATE置位启动ADC自动触发功能。ADCSRA的低3位ADPS[2:0]设置为110,分频比设为64。
Proteus运行截图:
Studio6.2编译通过截图:
程序清单:
  1. /*
  2. * GccApplication11.c
  3. *
  4. * Created: 2014-11-6 18:47:24
  5. *  Author: Administrator
  6. */
  7. #define F_CPU 4000000UL
  8. #include <avr/delay.h>
  9. #include <avr/io.h>
  10. #include <stdint.h>
  11. const uint8_t SEG_CODE[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xFF};
  12. uint8_t        Display_Buffer[] = {0,0,0,10,0,0,0,10};
  13. void ADC_Convert(uint8_t CH)
  14. {
  15.     int Result;
  16.         ADMUX = CH;
  17.         Result = (int)((ADCL+(ADCH<<8))*500.0/1023.0);
  18.     Display_Buffer[CH*4] = Result/100;
  19.         Display_Buffer[CH*4 +1] = Result/10 % 10;
  20.         Display_Buffer[CH*4 +2] = Result % 10;
  21. }
  22. int main(void)
  23. {
  24.     uint8_t i;
  25.         DDRA = 0xFC;
  26.         DDRC = 0xFF;PORTC = 0x00;
  27.         DDRD = 0xFF;PORTD = 0x00;
  28.         ADCSRA = 0xE6;
  29.         _delay_ms(3000);
  30.         while(1)
  31.         {
  32.                 ADC_Convert(0); ADC_Convert(1);
  33.                 for(i=0;i<8;i++)
  34.                 {
  35.                         PORTC = 0xFF;
  36.                         PORTD = _BV(i);
  37.                         PORTC = SEG_CODE[Display_Buffer[i]];
  38.                         if(i==0||i==4) PORTC &= 0x7F;
  39.                         _delay_ms(4);
  40.
  41.                 }
  42.         }
  43.
  44.
  45. }
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
