[i.MX] 用Mfgtools-Rel-12.04.01_ER_MX6Q_UPDATER烧制uboot和镜像时,会出错。
2260|2
 楼主| xumin3348 发表于 2014-11-11 17:28 | 显示全部楼层 |阅读模式
Tuesday, November 11, 2014 17:25:14
1 - Panel A Start processing Sabre-lite-timesys <LIST/>.
Panel A Start <CMD/> type="find" body="Recovery" file="" timeout="180" onError="" text="".
1 - Panel A Finished <CMD/> type="find" body="Recovery" file="" timeout="180" onError="" text="" SUCCESS code=0x0.
Panel A Start <CMD/> type="boot" body="Recovery" file="u-boot-mx6q-sabrelite.bin" timeout="10" onError="" text="Loading uboot.".
1 - Panel A Finished <CMD/> type="boot" body="Recovery" file="u-boot-mx6q-sabrelite.bin" timeout="10" onError="" text="Loading uboot." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel.".
1 - Panel A Finished <CMD/> type="load" body="" file="uImage" timeout="10" onError="" text="Doing Kernel." SUCCESS code=0x0.
Panel A Start <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs.".
1 - Panel A Finished <CMD/> type="load" body="" file="initramfs.cpio.gz.uboot" timeout="10" onError="" text="Doing Initramfs." SUCCESS code=0x0.
Panel A Start <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. ".
Failed to read HAB type from ROM!!!
Failed to get HAB type from ROM, ignoredro!!!
1 - Panel A Finished <CMD/> type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. " FAIL code=0x6.
Panel A: Reason is unknown,failed to run command: type="jump" body="" file="" timeout="10" onError="" text=" Jumping to OS image. "  2 - Panel A Finished processing Sabre-lite-timesys <LIST/> : FAIL code=6.
Panel A UtpUpdate Event: DeviceRemoval Msg: (null) DevState: Disconnected OpState: WAITING_FOR_DEVICE
但多试几次就ok了,这是什么情况?
FSL_TICS_Rita 发表于 2014-11-12 09:18 | 显示全部楼层
楼主你好,请问你这里使用的是哪块板子?还有你这里写的images是你自己编译的还是官网的Demo?你使用的是哪个版本的BSP?
 楼主| xumin3348 发表于 2014-11-12 11:13 | 显示全部楼层
板子是英蓓特的Sabre Lite开发板, BSP版本是u-boot-2009.08, image是官方的。 这个与烧录工具有关,与镜像无关吧。我重启了一下板子,然后就可以了。
