精灵一号程序---main.c
1315|2
 楼主| 雁舞白沙 发表于 2014-11-12 06:07 | 显示全部楼层 |阅读模式
//---本人所做,如有错误还望指正
#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430x21x2.h>
#define   PulseOneDirIn             P2DIR  &= ~BIT2//---'A'
#define   PulseTwoDinIn             P2DIR  &= ~BIT1//---'B'
#define   PulseThrDinIn             P2DIR  &= ~BIT0//---'C'
extern void PwmInit(void);
extern void PwmConn(unsigned int *DataDptr,unsigned int TimesliceFg);
extern void CommInit(long baud);
extern void ComConn(unsigned int *DataDptr,unsigned int TimesliceFg);
extern void LedConn(unsigned int *DataDptr,unsigned int TimesliceFg);
extern void MotoCon(unsigned int *DataDptr,unsigned int TimesliceFg);
extern void SetDcoConn(void);
extern void MotoInit(void);
extern void AutoRun(void);
extern void MotoRun(void);
extern void MotoDrv(void);
extern void AclkInit(void);
extern char TaPwmInit(unsigned char Clk,unsigned char Div,char Mode1,unsigned char Mode2);
extern void SinLowInt(unsigned char InitMode);
extern void SinHigInt(unsigned char InitMode);
void InitRTC(void)
    WDTCTL = WDTPW + WDTHOLD;                 // 禁止看门狗
    if (CALBC1_16MHZ ==0xFF || CALDCO_16MHZ == 0xFF)
        SetDcoConn();
    DCOCTL = 0;
    BCSCTL1 = CALBC1_16MHZ;
    DCOCTL = CALDCO_16MHZ;
    BCSCTL2 |= SELM_0 + DIVM_0;//---MCLK=16M
    WDTCTL=WDT_ADLY_16;//-----工作于定时状态
    IE1|=WDTIE;//--------------使能看门狗定时中断
int main(void)
    MotoInit();
    _DINT();
    InitRTC();
    CommInit(9600);
    PwmInit();
    SpeedData=3000;
    PulseOneDirIn;
    PulseTwoDinIn;
    PulseThrDinIn;
    _EINT();
    for(;;)
        LedConn((unsigned int *)&HigSpeed,0x0001);
        MotoCon((unsigned int *)&HigSpeed,0x0002);
//-----中断间隔0.016
#pragma vector=WDT_VECTOR
__interrupt void WDT_Delay(void)
    HigSpeed=0xffff;
    if(MotoErrTime!=0)
        MotoTime--;
    if(MotoStrTime!=0)
        MotoStrTime--;
    else if(MotoStrTime==1)
        MotoSt=0;
        SpeedData=2500;
    else
        MotoSt=0;
        AutoRunEn=0;
        SpeedData=2500;
        MotoStrTime=125;
zhimagod 发表于 2014-11-12 08:14 | 显示全部楼层
版主~~不来点介绍吗?精灵一号是个啥啊?
 楼主| 雁舞白沙 发表于 2014-11-13 08:51 | 显示全部楼层
自己做的电调
个人签名:学者会友QQ群:72137827 三人行,必有我师!
213
