[产品供应] 精度0.1%,温度系数15ppm/℃电阻,尺寸1206
1258|8
 楼主| mhfs 发表于 2014-11-13 10:35 | 显示全部楼层 |阅读模式
精度0.1%,温度系数15ppm/℃电阻1206
精度0.1%贴片电阻
温度系数15ppm/℃片式电阻
1206低温漂电阻
序号产品规格阻值尺寸精度温度系数功率规格书                       SPEC
4.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
5.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
5.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
6.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
6.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
7.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
8.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
9.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
10Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
10.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
10.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
10.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
13
11Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
14
11.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
15
11.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
16
11.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
17
12Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
18
12.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
19
12.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
20
12.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
 楼主| mhfs 发表于 2014-11-13 10:37 | 显示全部楼层
精度0.1%贴片电阻
精度0.1%贴片电阻
温度系数15ppm/℃片状电阻
21
13Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
22
13.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
23
13.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
24
14Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
25
14.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
26
14.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
27
15Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
28
15.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
29
15.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
30
16Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
31
16.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
32
16.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
33
16.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
34
17.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
35
17.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
36
18Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
37
18.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
38
18.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
39
19.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
40
19.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
温度系数15ppm/℃电阻
温度系数15ppm/℃电阻
精度0.1%贴片电阻
41
20Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
42
20.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
43
21Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
44
21.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
45
22Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
46
22.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
47
22.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
48
23.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
49
23.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
50
24Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
51
24.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
52
24.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
53
24.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
54
25.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
55
26.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
56
26.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
57
27Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
58
27.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
59
28Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
60
28.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
 楼主| mhfs 发表于 2014-11-27 16:58 | 显示全部楼层
精度0.1%贴片电阻
精度0.1%贴片电阻
光颉精密电阻 VIKING低温漂电阻
29.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
30Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
30.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
30.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
31.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
32.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
33Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
33.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
34Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
34.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
35.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
36Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
13
36.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
14
37.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
15
38.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
16
39Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
17
39.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
18
40.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
19
41.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
20
42.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
 楼主| mhfs 发表于 2014-11-27 16:59 | 显示全部楼层
温度系数15ppm/℃片式电阻
温度系数15ppm/℃片式电阻
光颉精密片状电阻 VIKING低温度系数电阻
21
43Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
22
43.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
23
44.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
24
45.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
25
46.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
26
47Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
27
47.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
28
48.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
29
49.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
30
51Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
31
51.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
32
52.3Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
33
53.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
34
54.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
35
56Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
36
56.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
37
57.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
38
59Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
39
60.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
40
61.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
 楼主| mhfs 发表于 2014-11-27 17:00 | 显示全部楼层
温漂15ppm/℃贴片电阻
温漂15ppm/℃贴片电阻
光颉精密电阻 VIKING低温漂电阻
41
62Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
42
63.4Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
43
64.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
44
66.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
45
68Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
46
68.1Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
47
69.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
48
71.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
49
73.2Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
50
75Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
51
75.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
52
76.8Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
53
78.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
54
80.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
55
82Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
56
82.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
57
84.5Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
58
86.6Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
59
88.7Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
60
90.9Ω
1206
±0.1%
±15        ppm/℃
1/8W
询价
个人签名:现货供应精密电阻,三洋高分子电容,钽电容,陶瓷电容,13718367383 010-82967213 www.mhbeijin.com  www.vk-dz.com www.mhtan.com
