[i.MX] imx6 ubuntu的系统,编译成功,也可以进入系统,但是USB不能用
995|2
 楼主| a1028732302 发表于 2014-11-13 15:59 | 显示全部楼层 |阅读模式
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Freescale On-Chip EHCI Host Controller
usb usb2: Manufacturer: Linux 3.0.35-2666-gbdde708 ehci_hcd
usb usb2: SerialNumber: fsl-ehci.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
mini1986 发表于 2015-4-19 21:06 | 显示全部楼层
楼主解决了没有?
mini1986 发表于 2015-4-19 21:07 | 显示全部楼层
楼主解决了没有?这么多重复的帖子......
