[DSP编程] 28335串口编程问题求解!
4577|15
 楼主| scottly 发表于 2014-11-14 14:30 | 显示全部楼层 |阅读模式
1.用网上买的开发板。上面用的是SCIC串口,接了MAX232电平转换芯片;和PC电脑串口通信正常,串口助手收发都显示正常;
2.自己公司的板子,用的是串口SCIB,接的是sp3232电平转换芯片;但串口什么数据显示都没有;数据格式、波特率都设置正确的;各位给点思路?
(PS:板子上SCIBTXD引脚先接到一个si8422芯片,用来做隔离的,再接的电平转换芯片;
   用示波器测量,程序里28335发送数据给PC时,SCIBTXD引脚有一个电平的跳变,但是经过si8422芯片后的SCIBTXD就没有波形的跳变了,会是这里的问题吗?)
 楼主| scottly 发表于 2014-11-14 14:34 | 显示全部楼层
贴上程序:
void main(void)
    Uint16 ReceivedChar;
    char *msg;
    InitSysCtrl();
    InitScibGpio();
//   InitXintf16Gpio();
   DINT;
   InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
// Step 5. User specific code:
    LoopCount = 0;
    ErrorCount = 0;
    scib_fifo_init();           // Initialize the SCI FIFO
    scib_echoback_init();  // Initalize SCI for echoback
    msg = "\r\n\n\nHello World!\0";
    scib_msg(msg);
    msg = "\r\nYou will enter a character, and the DSP will echo it back! \n\0";
    scib_msg(msg);
        for(;;)
       msg = "\r\nEnter a character: \0";
       scib_msg(msg);
       // Wait for inc character
       while(ScibRegs.SCIFFRX.bit.RXFFST == 0) {} // ==1 break->receive BUF has new DATA
           msg = "  You sent: \0";
       scib_msg(msg);
            // Get all character
           do
         ReceivedChar = ScibRegs.SCIRXBUF.all;
       // Echo character back
         scib_xmit(ReceivedChar);
                }while(ScibRegs.SCIFFRX.bit.RXFFST != 0);
       LoopCount++;
// Test 1,SCIA  DLB, 8-bit word, baud rate 0x000F, default, 1 STOP bit, no parity
void scib_echoback_init()
    // Note: Clocks were turned on to the SCIA peripheral
    // in the InitSysCtrl() function
        ScibRegs.SCICCR.all =0x0007;   // 1 stop bit,  No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
        ScibRegs.SCICTL1.all =0x0003;  // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
        ScibRegs.SCICTL2.all =0x0003;
        ScibRegs.SCICTL2.bit.TXINTENA = 1;
        ScibRegs.SCICTL2.bit.RXBKINTENA =1;
        #if (CPU_FRQ_150MHZ)
              ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 37.5MHz.
              ScibRegs.SCILBAUD    =0x00E7;
        #endif
        #if (CPU_FRQ_100MHZ)
      ScibRegs.SCIHBAUD    =0x0001;  // 9600 baud @LSPCLK = 20MHz.
      ScibRegs.SCILBAUD    =0x0044;
        #endif
        ScibRegs.SCICTL1.all =0x0023;  // Relinquish SCI from Reset
// Transmit a character from the SCI
void scib_xmit(int a)
    while (ScibRegs.SCIFFTX.bit.TXFFST != 0) {}
    ScibRegs.SCITXBUF=a;
void scib_msg(char * msg)
    int i;
    i = 0;
    while(msg[i] != '\0')
        scib_xmit(msg[i]);
        i++;
// Initalize the SCI FIFO
void scib_fifo_init()
        //ScibRegs.SCIFFTX.all=0x8000;
    ScibRegs.SCIFFTX.all=0xE040;
    ScibRegs.SCIFFRX.all=0x204f;
    ScibRegs.SCIFFCT.all=0x0;        //禁止串口自动检测波特率
wangch_sh 发表于 2014-11-14 15:05 | 显示全部楼层
你循环发一个固定的数,比如0x55,用示波器测SCIBTXD引脚波形是否正确。
如果正确的话,可以先试着把si8422芯片搞掉,或者跳线直接接到电平转换芯片上试试。
 楼主| scottly 发表于 2014-11-14 16:38 | 显示全部楼层
如果正确的话,可以先试着把si842 ...
SCI—A  B  C的寄存器配置都是一样的吧???
wangch_sh 发表于 2014-11-14 17:50 | 显示全部楼层
你现在用B,就把C都改成B就对了。
 楼主| scottly 发表于 2014-11-14 17:57 | 显示全部楼层
你现在用B,就把C都改成B就对了。
对的呀  就是这样改的,哎。。。
这块板子上用了A和B A由28335直接引出,B接了一个si842和sp3232芯片后引出,我写的程序使用A可以和电脑正常通信,换成B就不行;
一个简单的串口都没搞定。。。只能说太水了,关键硬件的问题比较难查。。。
wangch_sh 发表于 2014-11-14 17:59 | 显示全部楼层
A可以那就说明软件没问题。你用示波器测DSP的发送腿了吗?波形对不对?
zhangmangui 发表于 2014-11-14 18:28 | 显示全部楼层
这个应该是硬件的问题 隔离后你要确保有数据
 楼主| scottly 发表于 2014-11-14 18:52 | 显示全部楼层
发送脚有数据,但貌似经过隔离芯片后就没有了;
明天对比买的板子上的B测试一下。。。
 楼主| scottly 发表于 2014-11-14 18:55 | 显示全部楼层
嗯  大哥在帮我看看代码有没有哪边有问题
 楼主| scottly 发表于 2014-11-15 19:11 | 显示全部楼层
问题找到了,是硬件的问题,软件没问题。
sunyu817 发表于 2015-12-1 10:57 | 显示全部楼层
这个程序直接通过串口连接PC和开发板,应该怎么操作才能在串口调试工具上看到发送的字符串
