[讨论] stm32经SPI与OLED通信
2297|4
 楼主| crystal1987 发表于 2014-11-22 12:54 | 显示全部楼层 |阅读模式
请高手帮忙分析一下代码,看看那里有问题,现在代码能够正常运行,指示灯闪烁,就是OLED屏不能正常点亮?
//#define LCD_SCL_H  GPIO_ResetBits(GPIOB, GPIO_Pin_8)
//#define LCD_SCL_L  GPIO_SetBits(GPIOB, GPIO_Pin_8)
#define LCD_SCL PBout(8)           //时钟 D0(SCLK)
#define LCD_SDA PBout(9)           //D1(MOSI) 数据
#define LCD_RST PDout(6)           //复位
#define LCD_DC  PBout(5)           //数据/命令控制
extern void OLED_Init(void) ;
extern void LCD_CLS(void);
extern void LCD_P6x8Str(unsigned char x, unsigned char y,unsigned char ch[]);
extern void LCD_P8x16Str(unsigned char x, unsigned char y,unsigned char ch[]);
extern void LCD_P16x16Ch(unsigned char x,unsigned char  y,unsigned char  N);
extern void Draw_BMP(unsigned char x0,unsigned char  y0,unsigned char  x1,unsigned char  y1,unsigned char BMP[]);
#define XLevelL                0x00
#define XLevelH                0x10
#define XLevel            ((XLevelH&0x0F)*16+XLevelL)
#define Max_Column        128
#define Max_Row                64
#define        Brightness        0xCF
#define X_WIDTH 128
#define Y_WIDTH 64
/*********************LCD 延时1ms************************************/
void LCD_DLY_ms(unsigned int ms)
        unsigned int a;
        while(ms)
                a=1800;
                while(a--);
                ms--;
/*********************LCD写数据************************************/
void LCD_WrDat(unsigned char dat)
        unsigned char i=8;
        LCD_DC=1;
        for(i=0;i<8;i++) //发送一个八位数据
                LCD_SDA=dat&0x80;
                LCD_SCL=0;
                LCD_SCL=1;
                dat<<=1;
/*********************LCD写命令************************************/
void LCD_WrCmd(unsigned char cmd)
        unsigned char i=8;
        LCD_DC=0;
                LCD_SDA=cmd&0x80;
                LCD_SCL=1;
                LCD_SCL=0;
                cmd<<=1;;
/*********************LCD 设置坐标************************************/
void LCD_Set_Pos(unsigned char x, unsigned char y)
        LCD_WrCmd(0xb0+y);
        LCD_WrCmd(((x&0xf0)>>4)|0x10);
        LCD_WrCmd((x&0x0f)|0x01);
/*********************LCD全屏************************************/
void LCD_Fill(unsigned char bmp_dat)
        unsigned char y,x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                for(x=0;x<X_WIDTH;x++)
                        LCD_WrDat(bmp_dat);
/*********************LCD复位************************************/
void LCD_CLS(void)
        unsigned char y,x;
        for(y=0;y<8;y++)
                LCD_WrCmd(0xb0+y);
                LCD_WrCmd(0x01);
                LCD_WrCmd(0x10);
                LCD_WrDat(0);
/***************功能描述:显示6*8一组标准ASCII字符串        显示的坐标(x,y),y为页范围0~7****************/
void LCD_P6x8Str(unsigned char x,unsigned char  y,unsigned char ch[])
        unsigned char c=0,i=0,j=0;
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>126){x=0;y++;}
                        LCD_Set_Pos(x,y);
                for(i=0;i<6;i++)
                        LCD_WrDat(F6x8[c]);
                x+=6;
                j++;
/*******************功能描述:显示8*16一组标准ASCII字符串         显示的坐标(x,y),y为页范围0~7****************/
void LCD_P8x16Str(unsigned char x,unsigned char  y,unsigned char ch[])
        while (ch[j]!='\0')
                c =ch[j]-32;
                if(x>120){x=0;y++;}
                  LCD_Set_Pos(x,y);
                for(i=0;i<8;i++)
                  LCD_WrDat(F8X16[c*16+i]);
                LCD_Set_Pos(x,y+1);
                for(i=0;i<8;i++)
                  LCD_WrDat(F8X16[c*16+i+8]);
                x+=8;
                j++;
/*****************功能描述:显示16*16点阵  显示的坐标(x,y),y为页范围0~7****************************/
        unsigned char wm=0;
        unsigned int adder=32*N;  //
        LCD_Set_Pos(x , y);
        for(wm = 0;wm < 16;wm++)  //
                LCD_WrDat(F16x16[adder]);
                adder += 1;
        LCD_Set_Pos(x,y + 1);
                adder += 1;
/***********功能描述:显示显示BMP图片128×64起始点坐标(x,y),x的范围0~127,y为页的范围0~7*****************/
        unsigned int j=0;
        unsigned char x,y;
          if(y1%8==0) y=y1/8;
          else y=y1/8+1;
        for(y=y0;y<y1;y++)
                LCD_Set_Pos(x0,y);
            for(x=x0;x<x1;x++)
                        LCD_WrDat(BMP[j++]);
//初始化SSD1306
        GPIO_InitTypeDef  GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(        RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD, ENABLE );
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出                 SCLK - PB8  SDIN - PB9
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                                //                            DC - PB5
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD ;                  //推挽输出
        GPIO_SetBits(GPIOB, GPIO_Pin_5);
//        GPIO_Write(GPIOB,0X03);
        //               RST - PD6
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_SetBits(GPIOD, GPIO_Pin_6);
        LCD_SCL=1;
        LCD_RST=0;
        LCD_DLY_ms(50);
        LCD_RST=1;       //从上电到下面开始初始化要有足够的时间,即等待RC复位完毕
        LCD_WrCmd(0xae);//--turn off oled panel
        LCD_WrCmd(0x00);//---set low column address
        LCD_WrCmd(0x10);//---set high column address
        LCD_WrCmd(0x40);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
        LCD_WrCmd(0x81);//--set contrast control register
        LCD_WrCmd(0xcf); // Set SEG Output Current Brightness
        LCD_WrCmd(0xa1);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
        LCD_WrCmd(0xc8);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
        LCD_WrCmd(0xa6);//--set normal display
        LCD_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
        LCD_WrCmd(0x3f);//--1/64 duty
        LCD_WrCmd(0xd3);//-set display offset        Shift Mapping RAM Counter (0x00~0x3F)
        LCD_WrCmd(0x00);//-not offset
        LCD_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
        LCD_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
        LCD_WrCmd(0xd9);//--set pre-charge period
        LCD_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
        LCD_WrCmd(0xda);//--set com pins hardware configuration
        LCD_WrCmd(0x12);
        LCD_WrCmd(0xdb);//--set vcomh
        LCD_WrCmd(0x40);//Set VCOM Deselect Level
        LCD_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
        LCD_WrCmd(0x02);//
        LCD_WrCmd(0x8d);//--set Charge Pump enable/disable
        LCD_WrCmd(0x14);//--set(0x10) disable
        LCD_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
        LCD_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
        LCD_WrCmd(0xaf);//--turn on oled panel
        LCD_Fill(0x00);  //初始清屏
        LCD_Set_Pos(0,0);
int main(void)
        LED_GPIO_Config();
        delay_init(72);             //延时初始化
        OLED_Init();                        //初始化OLED
         LCD_P6x8Str(44,1,"2");
         LCD_P8x16Str(44,0,"SALER");
         LCD_P6x8Str(16,6,"315322339@qq.com");
         LCD_P6x8Str(34,7,"2014-11-22");
        while(1)
                LED4_OFF;
                delay_ms(1500); //延时1s
                LED4_ON;
 楼主| crystal1987 发表于 2014-11-22 16:58 | 显示全部楼层
搞了整整一天,问题已解决,IO口初始化的频率过高,将GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
中的GPIO_Speed_50MHz修改成GPIO_Speed_2MHz,问题就解决啦。
yinhaix 发表于 2015-6-2 16:43 | 显示全部楼层
mornsun 发表于 2015-6-2 17:12 | 显示全部楼层
谢谢分享
HORSE7812 发表于 2015-6-4 09:14 | 显示全部楼层
