[STM32F1] STM32 ADC采集,DMA传输 DMA中断处理
8119|13
 楼主| 仙人球W 发表于 2014-11-24 14:13 | 显示全部楼层 |阅读模式
//函数名称:ADC1_Mode_Config(void)
//功能描述:配置ADC1的工作模式为MDA模式
//输入:无
//输出:无
void ADC1_Mode_Config(void)
        DMA_InitTypeDef DMA_InitStructure;
        ADC_InitTypeDef ADC_InitStructure;
        /* DMA channel1 configuration */
        DMA_DeInit(DMA1_Channel1);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;                    //ADC地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //内存地址  ADC_ConvertedValue[15]一个数组
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = 15;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;                   //外设地址固定
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                                  //内存地址自加
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //半字
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                                                   //循环传输
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init(DMA1_Channel1, &DMA_InitStructure);
        /* Enable DMA channel1 */
        DMA_Cmd(DMA1_Channel1, ENABLE);
        DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE); //传输结束中断
        /* ADC1 configuration */
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;                        //独立ADC模式
        ADC_InitStructure.ADC_ScanConvMode = DISABLE ;                                //禁止扫描模式,扫描模式用于多通道采集
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;                        //开启连续转换模式,即不停地进行ADC转换
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //不使用外部触发转换
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //采集数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = 1;                                //要转换的通道数目1
        ADC_Init(ADC1, &ADC_InitStructure);
        /*配置ADC时钟,为PCLK2的8分频,即9MHz*/
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);
        /*配置ADC1的通道11为55.        5个采样周期,序列为1 */
        ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);
        /* Enable ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* Enable ADC1 */
        ADC_Cmd(ADC1, ENABLE);
        /*复位校准寄存器 */
        ADC_ResetCalibration(ADC1);
        /*等待校准寄存器复位完成 */
        while(ADC_GetResetCalibrationStatus(ADC1));
        /* ADC校准 */
        ADC_StartCalibration(ADC1);
        /* 等待校准完成*/
        while(ADC_GetCalibrationStatus(ADC1));
        /* 由于没有采用外部触发,所以使用软件触发ADC转换 */
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
//函数名称:DMA1_Channel1_IRQHandler
//功能描述:DMA中断 对AD采集值平均滤波
//输入:无
//输出:无
void DMA1_Channel1_IRQHandler(void)
        BYTE i;
        WORD ADC_ConvertedValue_TEMP=0;
        for(i=0;i<15;i++)
                ADC_ConvertedValue_TEMP += ADC_ConvertedValue;
        ADC_ConvertedValue_average = ADC_ConvertedValue_TEMP/15;     //全局变量
        DMA_ClearITPendingBit(DMA1_IT_TC1);
          DMA_ClearFlag(DMA1_FLAG_TC1);
//函数名称:void GPIO_Configuration(void)
//功能描述:ADC引脚配置
//输入:无
//输出:无
        //=======================ADC通道配置========================
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOB, &GPIO_InitStructure);                                // PB0,输入时不用设置速率
//函数名称:void NVIC_Configuration(void)
//功能描述:中断配置
//输入:无
//输出:无
       NVIC_InitTypeDef NVIC_InitStructure;
        /* Configure the NVIC Preemption Priority Bits */
       NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQn;
        NVIC_Init(&NVIC_InitStructure);
评分
参与人数 1威望 +3 收起 理由
mmuuss586 + 3 赞一个!
查看全部评分
mmuuss586 发表于 2014-11-24 22:51 | 显示全部楼层
这个好,谢谢楼主分享;
tianli1980 发表于 2014-11-25 10:54 | 显示全部楼层
STM32 ADC采集,DMA传输 DMA中断处理,感谢楼主提供的好资料,参考学习一下。
wnxyy 发表于 2014-11-28 17:09 | 显示全部楼层
感谢楼主分享,正要用了
zh113214 发表于 2014-11-30 17:19 | 显示全部楼层
信号采集,不得不学啊,但是个人觉得还是挺难的,,,
SkyYe 发表于 2017-3-24 18:18 | 显示全部楼层
一代掌门 发表于 2017-3-24 21:25 | 显示全部楼层
很实用的教程,多谢分享。
稳稳の幸福 发表于 2017-3-25 16:08 | 显示全部楼层
通过中断获取ADC到DMA厉害。
truesix 发表于 2017-5-8 14:39 | 显示全部楼层
非常感谢,很有用。
usysm 发表于 2017-5-8 17:21 | 显示全部楼层
这个还需要DMA中断?
usysm 发表于 2017-5-8 17:26 | 显示全部楼层
以前采样都是直接读取运算,DMA传输。
我不是 发表于 2017-7-19 20:21 | 显示全部楼层
  for(i=0;i<15;i++)
楼主这句写错了吧,既然ADC_ConvertedValue是个数组,应该写成ADC_ConvertedValue[i]呀
