串口发送数据串口调试助手显示RX没改变
1072|2
u880|  楼主 | 2014-11-27 15:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <msp430.h>
#include<stdio.h>
void USCI_A0_init(void)
      DCOCTL = 0; // Select lowest DCOx and MODx settings
      BCSCTL1 = CALBC1_1MHZ; // Set DCO
      DCOCTL = CALDCO_1MHZ;
      P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
      P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
      UCA0CTL1 |= UCSSEL_2; // SMCLK
      UCA0BR0 = 104; // 1MHz 9600
      UCA0BR1 = 0; // 1MHz 9600
      UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
      UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
      IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
      __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled
int main(void)
  WDTCTL = WDTPW + WDTHOLD; // Stop WDT
  USCI_A0_init();
  unsigned char sbuf[8];        /*待发送的内容*/
  unsigned int vol,curr,index=0;
  while(1)
      sbuf[0] = (unsigned char)0x55;    //头部,固定
      sbuf[1] = (unsigned char)((0x80)|(index & (0x3F<<16)));    //前两个bit为类型,此处以10B电压源数据为例,后6bit为index前6位
      sbuf[2] = (unsigned char)(index & (0xFF<<8));    //去除头6bit后的一个字节
      sbuf[3] = (unsigned char)(index & 0xFF);    //取index最后一个字节
      vol = (unsigned int)(20);    //电压,先按固定值20取
      curr = (unsigned int)(30);  //电流,先按固定值30取
      sbuf[4] = (unsigned char)(vol & (0xFF<<4));//电压数据前八bit放入第一个Byte
      sbuf[5] = (unsigned char)(((vol&0xF)<<4)|(curr & (0xF<<8)));//电压数据的后四位和电流数据的前4位
      sbuf[6] = (unsigned char)(curr & 0xFF);//电流数据的后8位
      sbuf[7] = (unsigned char)0xAA;        //尾部
      unsigned int i;
      for(i=0;i<8;i++)
          UartSend(sbuf);
#pragma vector=USCIAB0RX_VECTOR
void UartSend(unsigned char c)//发送字节函数
while(!(IFG2 & UCA0TXIFG));  //待发送为空
UCA0TXBUF=c;
IFG2 &=~UCA0RXIFG;
目前问题:连接串口,串口调试助手里显示的“RX”没有变化;若成功的发送的话不是应该在串口调试助手里看到“RX”增加吗?
求大神指教
430G2553
