编译提示内存不足怎么办
1139|4
 楼主| u880 发表于 2014-11-27 15:38 | 显示全部楼层 |阅读模式
"../28027_RAM_lnk.cmd", line 114: error #10099-D: program will not fit into available memory.  placement with alignment/blocking fails for section ".text" size 0x975 page 0.  Available memory ranges:
   PRAML0       size: 0x900        unused: 0x900        max hole: 0x900
error #10010: errors encountered during linking;
 楼主| u880 发表于 2014-11-27 15:40 | 显示全部楼层
PRAML0     : origin = 0x008000, length = 0x000900
这段要改大一点吗?
拿起书本 发表于 2014-11-28 10:26 | 显示全部楼层
建议楼主看看CMD文件,存储器分配可能不正确。
