| 单步运行还是全部图标都灰了 将main函数断点去掉后 就一直running image
 用的是0k6410的开发板  程序也是led的
 init.s
 IMPORT Main
 AREA Init, CODE, READONLY
 global start
 start
 bl Main
 END
 main.c
 #define rGPMCON (*(volatile unsigned *)(0x7F008820))
 #define rGPMDAT (*(volatile unsigned *)(0x7F008824))
 #define rGPMPUD (*(volatile unsigned *)(0x7F008828))
 void msDelay(int time)
 volatile unsigned int i,j;
 for(i = 0; i < 2000000; i++)
 for(j=0; j<time; j++);
 void GPIO_Init(void)
 rGPMCON = 0x11111;
 rGPMPUD = 0x00;
 rGPMDAT = 0X1F;
 void LedTest(void)
 volatile unsigned int i;
 while (1)
 for(i=0; i<4; i++)
 rGPMDAT = ~(1<<i);
 msDelay(10);
 void Main(void)
 GPIO_Init();
 LedTest();
 while(1);
