[DSP编程] CCS4.2导入工程的问题
1979|4
 楼主| wangch_sh 发表于 2014-12-6 17:45 | 显示全部楼层 |阅读模式
我把CCS3.3工程导入CCS4.2时,出现如下错误:
在migration.log文件里提示
!WARNING: Source file 'rts55x.lib' has been linked into the project relative to version-specific Code-generation Tool variable 'CCS_C5500_4_3_6_CG_ROOT'.
It is recommended, however, that you do not link any resources from the Code-generation Tool directory -
consider using build-options to reference include-files and libraries, or linking the resource into your project using a new version-independent variable.
这是什么意思?谢谢!
zhangmangui 发表于 2014-12-6 21:34 | 显示全部楼层
供参考
zhangmangui 发表于 2014-12-6 21:50 | 显示全部楼层
http://wenku.baidu.com/link?url= ... 07GoIqF18E3HuQvN7MO
有积分下载的朋友可以给大家分享一下
个人签名:为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
318
