[i.MX] 求教:关于i.MX6 编译视频编解码错误,谢谢!
1055|0
 楼主| 在那遥远的地方 发表于 2014-12-8 15:57 | 显示全部楼层 |阅读模式
单编译LTIB成功,配置也成功。按照论坛里《i.MX53 QSB LCD视频编解码上》和《i.MX_6_Series_Ubuntu_Multimedia_User's_Guide》文档编译了libfslcodec, libfslparser,libfslvpuwrap, gst-fsl-plugins, gst-plugins-gl, and fsl-alsa-plugins,gstreamer-plugins-good的包后总是提示这个错误! 请大虾们帮忙看看!万分感谢!
configure: *** checking feature: building of plug-ins with external deps ***
configure: building external plug-ins
checking size of void *... 4
checking whether byte ordering is bigendian... no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for arm-linux-gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking for gcc -std=gnu99 option to accept ISO Standard C... (cached) -std=gnu99
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... ld
checking if the linker (ld) is GNU ld... yes
checking whether the g++ linker (ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether gcc -std=gnu99 and cc understand -c and -o together... yes
checking for valgrind... no
checking whether to build gtk-doc documentation... no
checking for gtkdoc-check... no
configure: Looking for Python version >= 2.1
checking for python... /usr/bin/python
checking "/usr/bin/python":... okay
checking local Python configuration... looks good
checking whether to build plugin documentation... no (gtk-doc disabled or not available)
checking for library containing strerror... none required
checking for cos in -lm... yes
checking for ANSI C header files... (cached) yes
checking for inline... inline
checking whether gcc -std=gnu99 implements __PRETTY_FUNCTION__... yes
checking whether gcc -std=gnu99 implements __FUNCTION__... yes
checking whether gcc -std=gnu99 implements __func__... yes
checking for GLIB... yes
host is arm-unknown-linux-gnu
checking for fbGetDisplay in -lEGL... no
checking for X... no
checking X11/Xlib.h usability... no
checking X11/Xlib.h presence... no
checking for X11/Xlib.h... no
configure: cannot find X11 development files
checking EGL/egl.h usability... no
checking EGL/egl.h presence... no
checking for EGL/egl.h... no
checking GL/gl.h usability... no
checking GL/gl.h presence... no
checking for GL/gl.h... no
configure: error: GL or EGL is required, consider installing libgl1-mesa-dev
error: Bad exit status from /home/shkj-kelly/ltib/tmp/rpm-tmp.73736 (%build)
RPM build errors:
Build time for gst-plugins-gl: 6 seconds
Failed building gst-plugins-gl
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Mon Dec  8 14:43:51 2014
Ended:   Mon Dec  8 14:49:11 2014
Elapsed: 320 seconds
These packages failed to build:
gst-plugins-gl
Build Failed
Exiting on error or interrupt
