[STM32F1] STM32 DMA+ADC的问题?
1468|6
 楼主| qq344269956 发表于 2014-12-10 11:16 | 显示全部楼层 |阅读模式
各位大神,请表我看一下吧。我使用DMA+ADC 对一路信号进行采集,DMA和ADC配置为:
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
        /* Enable ADC1 and GPIOC clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE);
        //配置GPIO
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;//PA11-->DM  PA12-->DP
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        //配置ADC  和 DMA
  /* DMA channel1 configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADCConvertedValue;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = DISABLE ;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel8 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_1Cycles5);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC1, ENABLE);
IO口设置为:
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
直接使用固定变量对DMA过行测试,发现没有问题。
单步调试ADC时,采集值也是一样的,。。。。。
采集开始后,查询ADC的采集值一直为0x850~0x750之间,接高电平和接地都一样,这是怎么回来?
换用别的IO口进行采集也是类似情况。
我的电路是直接对串联电阻中间电压过行采集。
mmuuss586 发表于 2014-12-10 12:01 | 显示全部楼层
先去吃饭,等会来看;
mmuuss586 发表于 2014-12-10 15:42 | 显示全部楼层
看了下程序没什么问题;
但是:
你上面IO初始化了GPIO_Pin_11 | GPIO_Pin_12;
而IO设置最好也放前面;
我的AD程序,共2路,一路用的AD,一路用的DMA;
void Adc12_Init(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable DMA1 clock */
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1|RCC_APB2Periph_ADC2, ENABLE);
          /* Configure and enable ADC interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Configure PA.03 (ADC Channe3) as analog input -------------------------*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
          /* DMA1 channel1 configuration ----------------------------------------------*/
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&ADCConvertedValue;
  /* Enable DMA1 channel1 */
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_239Cycles5);
  /* Enable ADC1 */
  /* Enable ADC1 reset calibration register */
  /* Start ADC1 calibration */
          /* ADC2 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  ADC_Init(ADC2, &ADC_InitStructure);
  /* ADC2 regular channels configuration */
  ADC_RegularChannelConfig(ADC2, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
  /* Enable ADC2 EOC interrupt */
  ADC_ITConfig(ADC2, ADC_IT_EOC, ENABLE);
          /* Enable ADC2 */
  ADC_Cmd(ADC2, ENABLE);
  /* Enable ADC2 reset calibration register */
  ADC_ResetCalibration(ADC2);
  /* Check the end of ADC2 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC2));
  /* Start ADC2 calibration */
  ADC_StartCalibration(ADC2);
  /* Check the end of ADC2 calibration */
  while(ADC_GetCalibrationStatus(ADC2));
        /* Start ADC2 Software Conversion */
  ADC_SoftwareStartConvCmd(ADC2, ENABLE);
