MAX6955也是一种紧凑型的显示驱动器,IIC接口,可驱动多达16位7段、8位14段、8位16段或128个分立的LED.本程使MAX6955工作于全解码模式,因此只需要向MAX6955输出待显示字符ASCII码即可,不需要编写并发送各字符的段码。
Proteus仿真结果:
Studio6.2编译通过的截图:
程序清单:
- * GccApplication32.c
- * Created: 2014-12-11 22:11:01
- * Author: Administrator
- #define F_CPU 4000000UL
- #include <avr/io.h>
- #include <util/twi.h>
- #include <util/delay.h>
- #include <string.h>
- #include <stdint.h>
- #define MAX6955R 0b11000001
- #define MAX6955W 0B11000000
- #define Wait() while((TWCR & _BV(TWINT))==0)
- #define START() {TWCR = _BV(TWINT) | _BV(TWSTA) | _BV(TWEN);Wait();}
- #define STOP() (TWCR = _BV(TWINT)| _BV(TWSTO) | _BV(TWEN) )
- #define WriteByte(x) {TWDR=(x);TWCR = _BV(TWINT)|_BV(TWEN);Wait();}
- #define ACK() (TWCR |= _BV(TWEA))
- #define NACK() (TWCR &= ~_BV(TWEA))
- char SEG_LED_String[] = "01234567890";
- uint8_t MAX6955_Write(uint8_t addr,uint8_t dat)
- START();
- if(TW_STATUS != TW_START) return 0;
- WriteByte(MAX6955W);
- if(TW_STATUS != TW_MT_SLA_ACK) return 0;
- WriteByte(addr);
- if(TW_STATUS != TW_MT_DATA_ACK) return 0;
- WriteByte(dat);
- STOP();
- _delay_ms(20);
- return 1;
- void MAX6955_INIT()
- MAX6955_Write(0x01,0xFF);
- MAX6955_Write(0x02,0x03);
- MAX6955_Write(0x03,0x07);
- MAX6955_Write(0x04,0x01);
- MAX6955_Write(0x06,0x00);
- MAX6955_Write(0x0c,0x00);
- MAX6955_Write(0x07,0x01);
- _delay_ms(1000);
- MAX6955_Write(0x07,0x00);
- int main(void)
- uint8_t i,j,Len = strlen(SEG_LED_String);
- DDRD = 0xFF; PORTD = 0x00;
- MAX6955_INIT();
- while(1)
- //TODO:: Please write your application code
- for(i = 0;i<Len;i+=8)
- for(j = 0; j< 8;j++)
- MAX6955_Write(0x20 | j,(uint8_t)SEG_LED_String[i+j]);
- for(;j<8;j++)
- MAX6955_Write(0x20 | j,(uint8_t)(' '));
- _delay_ms(2000);
